Part # request
Part # request
I changed out the pollen filters and dropped a round metal nut that holds the pollen filter cover in place, it is on the opposite side of the clip and about the size and shape of a nickel. I've searched but I cannot locate the part number. Thanks for the help.
Technical Guru
Depending on where you dropped the nut (i.e. not into the HVAC ducting), it might be worth crawling under the car and removing the fuel pump cover, dropped fasteners have a habit of ending up there!
