Fabspeed Maxflow Exhaust
Does anyone know whether the standard Fabspeed Maxlflow exhaust and tip will fit a 993 C4S which I'm sure you all know has increased distance between the two exhaust tips than the standard body and even the 993TT?
If not can I replace the fabspeed tips with the OEM tips which are offset to fit the C4S?
Finally does anyone want to tell me how the noise compares to RSR's?
I have a set of the narrow body Maxflows that I would like to sell.
You would need to use the Maxflow tips as the outflow pipe is shorter than the stock units and the stock units will not work.
Levino
Levino
Thanks for the prompt reply.
I take it you are saying the narrow body Maxflows and tips will not fit the my widebody C4S and neither will the standard body Maxiflow fitted with the C4S OEM offset tip fit the car? Looks like I will have to use RSR's.
Good luck with selling your Maxflows in Canada
I have Maxflo's and their tips fit my C4S. According to Joe at Fabspeed the same tips fit the wide and narrow body they are just put on in reverse.
I was told by Robin and Joe that the max flo's are a little loader than RSR's, but when I heard Evan's at a recent cruise in NY his RSR's seemed a little deeper and throatier than mine?
If Tom is correct then I have what you need.
The advantage of the Maxflows is that they are virtually a straight pipe bent into a U. I don't know about the internals of the RSR but I am guessing that there are more angles and are a little more restrictive.
Levino
Levino
