brake discs
brake discs
Excuse my ignorance chaps.
I have noticed some fine (hairline) cracks(?) on the drilled brake rotors. Does this mean that the discs need replacing?
Harry
Harry
Passed On
Actually, to give you nightmares, Porsche sez to replace them if the cracks get longer than 7mm (about 1/4 in). The cracks don't connect, in my experience (5th rotor set in 77K miles); they radiate in a radial direction in and out which is not in line with the other drilled holes. So you might take another look and maybe plan a replacement.
