993 Forum 1995-1998
Spoiler Wall Replacement Simplified
Old Jul 24, 2003 | 04:58 AM
Dudley's Avatar
Dudley
Default Spoiler Wall Replacement Simplified
I ordered the sticker, ala BradB, and a new spoiler wall for my 993. The original wall had little tears on either side and was due for replacement.
I applied the sticker to the Spoiler wall and then I down loaded instructions for the replacement. As ususal, I could not find the proper tool for the task at hand, I had to improvise. The damn thing snaps in and out without removing anything!! I open the spoiler all the way, unsnapped the top edge, unsnapped the stud, leaned the wall back, unsnapped the bottom edge, and pulled the old wall off the rubber track. (I taped the edge of the spoiler opening to prevent scratches.)
Install was simple as well. I slid on the new wall, snapped in the bottom, and then snapped in the top. The top goes best with the hood open so that you can fit you hand underneath and work the top edge along the spoiler. Very easy - no tools. Well I did use a little "Pledge" to help things along and I suggest you protect the bottom of the hood - just in-case you drop your flashlight. "Ask me how I know." )
Dave
Old Jul 24, 2003 | 07:09 AM
MadMarkie's Avatar
MadMarkie
Dave,
Thanks! My new wall is on order with the local stealer... hope to replace it this weekend. Your tip should leave me more time to watch Le Tour, and drink beer!
Mark.
Old Jul 24, 2003 | 08:00 AM
cmoss
Guest
Posts: n/a
I'll be needing to do this too! Thankx.
Pun? Typo? Freudian slip? Either way LOL!!!
Old Jul 24, 2003 | 08:15 AM
MadMarkie's Avatar
MadMarkie
Hi Cmoss,
"Stealer"... one of my new favorites, picked up lurking around here. Unfortunately, it's not really punny (sorry) since it involves wallet weight reduction.... just tellin' it like it is!
Cheers, Mark.
Old Jul 24, 2003 | 05:04 PM
mike cap's Avatar
mike cap
Dudley
I had my spoiler wall "in stock" and was waiting till I had a couple of hours based on the DIY at p-cars.com.
Anyway followed your mini-DIY and did it this evening in about twenty minutes. No tools needed - just a little muscle and finese. Perfect.
You da man. Thanks.
Mike Cap
1997 C2
Arena Red
Old Jul 24, 2003 | 05:52 PM
randyvitaha's Avatar
randyvitaha
Thumbs up
I just put my new spoiler wall on last night. It was quite easy if you follow the directions from P-car .com. I also used a lubricant to make the top "snap" in easier. The PORSCHE decal looks awesome on the wall. A couple of terry cloth towels laid across the bottom of the hatch saves the bottom of the rear hood from any scratches that might happen if you should "slip" or something. This is a great improvement!
Old Jul 25, 2003 | 03:51 AM
Dudley's Avatar
Dudley
Mike - you may own the replacement record! I will check with Guinness.
Robin's method is fool proof but the bolts that attach the spoiler seemed very soft and stubborn. I actually discovered my method while waiting for the "Liquid Wrench" to soak in. If a bolt can be stripped - I am sure to strip it.
Dave
Old Jul 25, 2003 | 04:04 AM
mike cap's Avatar
mike cap
Dudley,
Actually, I started to do it your way and the spoiler wall was a little stubborn, so went to Robin's DIY instead. I have all the tools, but you're right about the four socket head bolts. Easy to strip and very tight. I had visions of myself at 1 AM drilling one of them out and having the car down for days while I ordered replacements.
So, I went back to your procedure and got it done. Thanks again.
Mike Cap
1997 C2
Arena Red
