993 Weighted Shift Knob Confusion
2 Attachment(s)
Hi ---
May I ask a question about shift knobs? I'm a bit baffled myself. I have a 1996 C2 with a stock black-insert shift knob, and I bought an OE shift knob with an aluminum insert from a fellow rennlister. When I received the shift knob I noted that it is weighted heavier than my C2 shift knob ---- doing some searches revealed to me that the new shift knob is prob from a C4 or C4S. Okay …. but I cannot figure out how the heck I am supposed to attach this shift knob to my shift lever! The opening to slot onto the shift-shaft seems WAAAAAAY larger that my original one. Any clues guys? Am I missing a black rubber insert to "neck down" the new shift knob to my car? or is the new shift knob supposed to come with some kind of clip? Or both? Thanks… (pictures attached comparing old to new) |
there should be i believe two rubber inserts in the AWD shift knob to neck it down. The metal snap ring is presumably there to keep them in place.
once you get them, put a tiny bit of dish soap onto either the shaft or the rubber (boy that sounded dirty) to ease install. |
Thanks! That was fast! Anyone know the part numbrers for the two rubber pieces and the metal snap ring?
I have just the rubber inserts but no clip on mine. It works fine.
Originally Posted by Jlaa
(Post 11058994)
Thanks! That was fast! Anyone know the part numbers for the two rubber pieces and the metal snap ring?
931 424 111 00 931 424 110 00 snap ring: 993 424 299 00 |
Wow that was fast! Thanks! !!! !!!!!!!
1 Attachment(s)
Hi -- update -- -spoke with Andraya at Sunset. She said she's not really sure if the "wide mouth" knob (ostensibly from a C4 or C4s) can fit a C2's "shift shaft" where the C2 "narrow mouth" knob should go [yes i know it sounds so dirty this is not intentional] because the parts catalog shows that a C4 has a different "shifting shaft" than a C2.
That said, I am using FD Motorsports' "shift shaft" anyways and FD doesn't make a distinction between C2 and C4 .... I just ordered parts 34, 35, and 36 on this diagram and hope it fits! Thanks Guys |
When I installed the C4 weighted knob in my C2, the rubber bushings did not take up enough slack to my liking. So I drilled and tapped the forward portion of the metal housing (after peeling the leather back) and installed a short hex head cap screw. It works great.
Not sure about the FDM lever size. Regards, . |
Do you have the SSK? My SSK was done at FD, and the weighted shift knob fits just fine on the shaft.
Yes, I also have the FDM Goldenrod & SSK. Great then! I'll report back how well the rubber bushings and steel clips works with the weighted shift knob on my C2.
Actually I'm very intrigued to see what the additional weight of the shift knob will do. It is A LOT heavier than the C2 shift knob. With the standard C2 shift knob weight and FDM SSK/GR as well as fresh Redline 75W90NS fluid in the transmission, shifting is already sublime. Can it get any better? I had purchased the weighted knob purely for looks --- I like the aluminum gear-pattern insert and my current C2 knob is worn .... additional weight is an unexpected bonus... |
You'll love the additional weight of this shifter. It definitely makes the shifting easier and smoother with less effort with each throw.
C2 and C4 knobs are completely interchangeable with those rubber dampers and the "C" clip
Dumb question --- thanks for entertaining this ---- I just received parts 34 and 35. From the diagram it looks like I need to squeeeeeeeze and compress 34 to fit INSIDE 35. (diagram above) ---- can someone confirm this is the case?
Thanks! |
No, 34 goes in the end, 35 goes halfway up
No. The one that necks down goes into the shift knob first, and the second rectangular one goes next. they shouldn't go inside one another.
