HTR Z III: Anyone seen this kind of tire failure?
#31
I use the Sumis as my daily driver tires, and the rain option at the track. I agree that they are a fabulous bang for the buck.
I think th op got his money's worth. Any brand of tire, when run down to that tread level, cannot be trusted.
#32
Of course, the Sumi will be no match for the best performance tire, say, Michelin offers. But the Michelin is probably double the price, if not more.
The question become then, is it twice the tire?
Of course, if you're an incredibly skilled track rat with money to burn vying to shave tenths off your lap time, the Michelin is the way to go.
But for your average Joe driver, the Sumi probably is enough tire for the usual city and highway drives
Sumi's performance aspect is not the concern and i'm not comparing them to 500 a tire michelin, which btw is expensive not because it's much better on the track.
My concern is that i don't know where the cost savings come from even compared to the next cheapest tire. I just don't think there is 50% margin that sumi was able to magically find. Maybe it's thread life that gives, maybe worse cold performance, maybe higher chance of blow out. Second picture above clearly shows that costs were cut and it's not the trade-off that I would want.
#33
You missed my point, but that's ok because your argument will be always be to defend sumi's since you have them.
Without a proper assessment from a tire expert, we don't know that cost-cutting was a factor. It's also possible that the Michelin is priced twice as high because people of a similar mind-set to yours will pay double for a fractional gain; a manufacturer's favorite customer.
I don't really have any brand allegiance to Sumi or any other manufacturer. I simply went to Tire Rack and looked at their independent testing. So, instead of assumptions and hypotheses, I chose to defer to experts in the tire field and bought the Sumis based on their conclusion. Sure beats guessing and brand shopping without empirical data, at least for me
#34
#36
Uhh, you told me "your argument will be always be to defend sumi's since you have them." That's not what I think. I don't care about brand name. I care about a great tire at a fair price. Many on this board have found Sumi HTRZ IIIs to be great tires for the price.
OK Jersey, enjoy the weather back there and take care
#37
IMO, what you see in pic 1 and 2 is nothing unusual for any brand. My little brother is older now, but still into the "import scene". You see cars (Honda, Lexus, VW, etc…) running bad alignment, unknowingly or on purpose, day in and day out, to achieve the stance. Tires can be a year old with 80% tread life, but due to camber, the inside edges are worn to the cord. Just my observation.
#38
This is my conclusion.
I cannot know whether you know anything or not, but I would suggest to you that your habit of trying to wring out the very last mile an over-worn tire can possibly give you, surely suggests you may have more to learn when it comes to tire life and degradation.
How tires are mounted, used, maintained and whether they are properly inflated and aligned can all affect how tires wear.
Good luck. Get new tires please
The tire is rated for 186 mph and XL loads. This tire never went over 72 mph on the back end of a 3200 pound front engined car. I showed you the same failure on a tire with so much tread that you can't possibly contend this failure (at 40-45 mph) is treadwear related. Don't be silly.
I think cheaper owners are far more dangerous than cheaper tires.
Many, including myself, have run this Sumi HTRZ III tire and find it to be one of the best performance tires out there, regardless of cost. When price is factored in, it may arguably be the best overall performance tire around
Those who took sumi III to track may disagree with you. Also the second pic of Dr No is not promising either.
Im always suspect of something that is claimed to be much better or much cheaper. In such a competitive industry you can't make the same tire for 25%-50% less, something has to give. I don't want to find out which part will give.
Having worked for one of the N.A. majors for almost ten years I can tell you the root cause analysis is pretty complicated on failures like this. As a start this guide may help, we used it on a fairly regular basis when determining the validity of claims specific to owner caused failure as a result of neglect vs inherent manufacturing defect during production etc.
Type "Radial Tire Conditions Analysis Guide" into google and the PDF will come up with picture guides and explanations for almost all radial tire irregular wear patterns, failures etc. Too big to attach via pdf.
#39
Agree on all points, but please look at the picture at post 21. Not trying to start an argument, just trying to share what I've found.
#40
Regarding checking tire wear at each fill up...it's tough as hell to gauge inside wear on our cars, especially if they are lowered. Sometimes, running your hand along the outside tread blocks can feel the damage starting. All the more reason for a quality alignment, with sensible settings for intended use, and closely watching tire pressures.
Amazing that this thread degraded(somewhat) into another tire brand debate. Hey...you want to put only P, or N rated aka Porsche approved rubber on your car, good for you. Probably not an issue to drop $1500 on a set of tires if you only drive 2,3, or 5K miles per year. For me, it simply makes no sense to burn thru a $1K set of Michelin rears every season...maybe even have to put a second set of rears on before the driving season is over, considering I average almost 10K miles per year.
Are Michelin's a better tire than Sumi's, or Hankook's...absolutely. Are they worth twice the money, absolutely not. Why are Michein's, Goodyear's, and Yokohama's so much more than some other brands...it's all in the name baby. How many actual tire manufacturers are there in the world anyway, there are so many brands under each major name's roof, it's ridiculous.
So, maybe the Sumi's, and Hankook's are last generation tire tech, compared to the company's flagship brand. IMHO, that most current technology ain't wirth a factor of 2 to me.
#41
Sorry, I didn't meant to be condescending, but from the picture and your own statement, it appeared you might be unaware about all things tires.
My sincere apologies to you and your Carnak. Have him buy new tires too. It's cheap and safe insurance
#42
I can only go from what you yourself said: "it's dry and warm and flat here, so we may try to squeeze a few more miles out of beater tires on the grocery getter" and from the over-worn conditions on the tires you feel are OK to drive on that you posted.
#43
a gem bubbles up from amongst the heated discussion.
thank you Pags
#44
Catastrophic de-lamination!
Was watching Fifth Gear tonight on DWHD and on one of the segments a similar tire failure as the OP'r.
Check this link, click on segment 4 and watch the beginning of the video re: Catastrophic de-lamination on the GTR at 155m/h! And those were fairly new. Yikes!
