993 Forum 1995-1998
Creaking windscreen.
Old Apr 7, 2014 | 01:09 AM
therossinator's Avatar
therossinator
I tried the cord. Only a very slight decrease in noise. Maybe 5%.
Old Apr 7, 2014 | 05:08 AM
orangecurry's Avatar
orangecurry
As it has not been explained to the OP, the 'rope' is a Porsche approved solution for the 996.
Old Apr 7, 2014 | 11:52 AM
duverne996's Avatar
duverne996
Originally Posted by mike cap
Did you use the foam cord or just the Pedro's.
Hi Mike!
Well, when I removed portion of the rubber sealing around the windscreen, I discovered that it already had theis grey rubber/foam spoungy cord!
So i purchased a bottle of this Pedro's Wax thing. I used half of the bottle. The result so far quite good.
Lets see for how long!
Thanks again for your tips!
Old Apr 7, 2014 | 01:48 PM
Glassy's Avatar
Glassy
993 windscreens creak primarily due to poor fitting. The noise is generated by movement in the glass where it has been bonded/positioned incorrectly, or that there is little (or no) contact at all between the two contact surfaces. This is a very generalised synopsis, but other than trim frame issues, the problem - IME - is usually attributed to a poorly fitted windscreen.
Old Apr 7, 2014 | 04:03 PM
mike cap's Avatar
mike cap
Originally Posted by duverne996
Hi Mike!
Hello my friend. The rest of the Pedros you can use on your bicycle chain !!
Old Apr 8, 2014 | 08:29 PM
pp000830's Avatar
pp000830
Get some 100% silicone clear bath caluk. Inject it between the seal and the glass and if desired the body and the seal. Will quiet things right down. I did this once and it was the end of the issue.
Old Apr 8, 2014 | 08:48 PM
ttw18's Avatar
ttw18
I thought about the silicone caulk, but wondered if one might be inadvertently blocking drains in the windshield channel.
Old Apr 8, 2014 | 09:09 PM
CaptainGSR's Avatar
CaptainGSR
+1 Strut brace completely eliminated the creaking for me.
Old Apr 8, 2014 | 11:12 PM
autobonrun's Avatar
autobonrun
Mine only creaks from the rear window and only when it flexes backing out of the driveway. It doesn't creak when coming in. I find playing ZZ Top's La Grange at a high volume for 3 seconds eliminates the creak. Seriously, if it's only when I back out I've decided to leave well enough alone. But I may look into the Pedro's Ice Wax since it seems simple to do.
Old Apr 9, 2014 | 01:40 AM
GC96's Avatar
GC96
There aren't any drains in the windshield channel. It would be nice if there were that would help prevent some of the issues with rust developing around the windshield. There's a Porsche TSB about filling in the channel for both the windshield and rear window using a polyurethane sealant. You can find the TSB here (#3 under body and interior TSB's) http://pcarworkshop.com/index.php/99...C_Parts_Guides. The sealant that they mention in the TSB has been superseded and now they use Wurth Bond+Seal. There's a DIY post here by Bruce7 showing the procedure. There have also been some discussions here about the suitability of silicone sealant for use on cars because some types of silicone sealant release some amount of acetic acid when as they cure.
GC
Old Apr 9, 2014 | 08:43 PM
pp000830's Avatar
pp000830
All you ar putting is a small bead of calk in place not pumping in a large amount. The sound comes from the rubber sliding against the glass or against the body, you are using just enough to stop the movement. Just a small bead about the size of 12 gauge insulated primary wire.
Old Apr 10, 2014 | 12:07 AM
Ed Hughes's Avatar
Ed Hughes
I've posted it before. The current seals have a "flocking" on the back-almost a felt texture, that doesn't have the solid grip/creak.
Old Oct 5, 2014 | 01:27 AM
Spokes's Avatar
Spokes
I didn't have creaking with the new screen, but had some wind noise above 100Kph. Eliminated the wind noise with the rope.
Old Oct 5, 2014 | 11:32 AM
Paolo1's Avatar
Paolo1
These old 911s are just creaky, smokey VWs…You should probably get a new model and let me dispose of that old one for you
Old Jun 15, 2015 | 10:33 AM
nr1416's Avatar
nr1416
Just an update.
I installed the OEM Porsche rope 4 years ago and it worked perfectly but now the problem has come back. So I'm going to try the Wax, I've heard from another local 993 owner his uses Maxima chain wax. I'm guessing Pedros and Maxima are both similar products.
Since both the rope and wax are temporary solutions, I think the wax is a cheaper and quicker fix from the sounds of it.
