Brembo Evolution Brakes?
2nd Gear
Does anyone have experience with the Brembo Evolution brake upgrade for the 993? Does anyone know if it is possible to move the stock front calipers and rotors to the rear after putting the Evolutions on the front?
I would appreciate any thoughts and/or comments.
RL Technical Advisor
Hi Ben:
We have installed a good number of these Brembo EVO brakes on several 993's; street cars and some Cup cars.
The Evolution front brakes are intended to be used with TT rear calipers and rotors, and will not match up properly with 993 front brakes installed on the rear.
If you use the EVO front brakes, make sure your cars has the 322mmx28mm rear rotors and 993 TT calipers with 30/36 caliper pistons.
