993 Forum 1995-1998
Windshield Still Creaking
Old 07-22-2003 | 02:06 AM
ksimpson's Avatar
ksimpson
Angry Windshield Still Creaking
Last week my OPC fitted a new windshield and the "rope" fix. I also fitted a strut brace. The creak was gone for a couple of days and now it's back with a vengence.
The strut brace appears to be tight and was installed as detailed several times on this board.
I then got a Teflon based spray towards the end of last week which seemed to cure it. However, the creak was back last night. I applied some more of the Teflon spray, but I don't think it will keep it away for too long.
The Teflon spray doesn't appear to be viscous enough and is most likely evaporating - it's very similar to WD-40 in look and smell. I have ordered some Pedro's Ice Wax and will give that a try later this week.
Old 07-22-2003 | 05:42 AM
Caveman's Avatar
Caveman
Hi Ken,
It looks like it's the hot weather as mine is playing up as well (see your other post). Out of interest, which strut brace did you go with and was it expensive (say more than £150)? I'm thinking of treating myself to one. Did it make a lot of difference?
Thanks,
David
Old 07-22-2003 | 06:01 AM
ksimpson's Avatar
ksimpson
I went for the standard one Gert sells. See www.carnewal.com.
The car feels a lot better on corners and there appears to be less flexing. I think you should get one for well under £150. Only takes about 30 mins to install.
Old 07-22-2003 | 06:02 AM
Caveman's Avatar
Caveman
And did it make a lot of difference to the handling/feel of the car?
Old 07-22-2003 | 06:25 AM
ksimpson's Avatar
ksimpson
I think it did, but haven't really had a chance to push the car too much.
Old 07-22-2003 | 07:27 AM
Labatt's Avatar
Labatt
See my Mobil1 post... The dealer (creatively, I guess) put Mobil1 on my seals about 3 weeks ago and the windshield is still noise free. It had been absolutely horrible prior. I wouldn't have thought about using it, and the jury is still out as to whether it can cause paint or metal damage, but being stuck with it I would have to say that it seems to have done the trick.
Old 07-22-2003 | 07:32 AM
ksimpson's Avatar
ksimpson
If all else fails, I may consider the Mobil 1 route. I think the problem with the other lighter lubricants is that they evaporate, especially in hot weather.
Old 07-22-2003 | 07:55 AM
swftiii's Avatar
swftiii
Another lube that people have discussed is Pedros Ice Wax. It is a bicycle chain lube. If you give it a shot, be sure to buy it in an aerosol can. Most times it is in a squeeze container instead and this can be very difficult to use.
Good Luck
Old 07-22-2003 | 08:12 AM
max911's Avatar
max911
when i first purchased my car, i used a silicon spray as there was no Pedro's available where i was. it would start to loose its effectiveness in a matter of days, and immediately after a carwash. my first application of Pedro's got rid of 90% of the squeaks for about 2 weeks. i reapplied the ice wax and the squeaks were gone for months. In January i was starting to get the odd squeak, so put on two applications of Pedro's about 3 days apart. i used LOTS, making a mess!! (i had the non-aerosol container this time). the windshield has been squeak free for about 6 months now. good luck, max
Old 07-22-2003 | 09:58 AM
914und993's Avatar
914und993
Where are you applying the Ice/Wax or other lubricant, exactly? Inside/Outside? Pulling up the lip or what?
Thanks,
Chip
Old 07-22-2003 | 12:30 PM
max911's Avatar
max911
outside rubber seal; between seal lip and windshield frame (body). first, wash the car so that there is no grit around the winshield. then i use a wooden chopstick or tongue depressor to lift the lip of the seal. i insert the straw from the aerosol can behind the lifting device, and work my way around the windshield.
Old 10-13-2003 | 12:44 PM
forest's Avatar
forest
Max,
any clean-up work required after spraying, i mean like would the wax ooze out of the gap after driving for a while?
Old 10-13-2003 | 01:03 PM
NickC4S's Avatar
NickC4S
Did the Pedro's Ice Wax DIY this weekend. Outside and inside of seal, with plenty of mess.
First drive in the car - no sqeaks, except from the rear screen!
Applied Pedro's to the rear screen - no squeaks, except from the side windows!
However, the front and rear are silent. Mine was bad. I live in Atlanta and use the car daily with 90plus heat, to play expansion games on the seals.
Also did the 3rd brake light DIY from Robin's site. Had 2 lights out. When I got the cluster out, actually all the bulbs were all functioning - tested with a spare battery - but glowed dimmly. I actually bought 4 spare bulbs - approx. $10 from dealer - as a precaution and then re-soldered all 4 in place. Have a couple of darkening bulbs, still in place, so will probably need to repeat the DIY again. My recommendation is to buy a good stash of bulbs just in case. Good DIY. Less than 2 hours to complete. $15 for soldering iron, $10 for bulbs.
Nick
Old 10-13-2003 | 01:52 PM
tmario's Avatar
tmario
Hi, I am relatively new as I just purchased a 97 993TT. The window squeaking is ridiculous. I missed any previous post. Is this a common problem? Is there some dealer fix to this?
Thanks.
Old 10-13-2003 | 02:16 PM
swftiii's Avatar
swftiii
tmario,
This is just one of the common noisees that Porsche owners deal with. You can get back to previous posts using the search function in the top right corner of the web page.
There are different solutions for fixing it and the more knowledgeable dealers have a solution that can be used (rope...), but I'm not convinced it is a 100% solution.
I have used the Pedro's Ice Wax (make sure it is in the aerosol form) and after the second application the sqeek is gone.
FYI - try to focus on the sweet tunes coming from behind you and not the rattles - it took me a while to be successful in this, but it has made the drives more fun. And remember this is a 5-8 year old sports car and not a luxery car.
Good Luck
-Skip
Quick Reply: Windshield Still Creaking
