replacing oxygen sensor help
I will be attempting to replace the oxygen sensor on the passenger side. This is the one before the cat. For anyone who has done this-- would appreciate any tips? Where exactly is it located? do i need the special wrench to install? where does the end of the wire go-- some wiring harness somewhere? how long should i plan for this job? thanks, peter
Have you gotten underneath the car & looked yet? Do you have the replacement part? That helps you to know what you're looking for. Those things aren't typically torqued down very hard, so you can probably get away with an open-end wrench.
