Key lock fob mystery?
Why would a fresh battery in the lock fob be depleted in 3 days aside from the obvious possibility that the activating button could have been continuously depressed?
The first incident resulted in the alarm fandango in a parking lot. The second in
an emergency cross town key delivery.
Could a component failure in the fob cause unusually high current drain?
Gotta get an external magnetic key case for a battery.
Thanks,
-rbeggs
Thanks,
-rbeggs
Received 5,414 Likes
R u sure the battery was "fresh"?
There could be an internal short.
I have noticed that a significant amount of lint that accumulates inside the remote. While not a great conductor, I suppose enough fibers in the wrong place could cause problems. More likely an open, than a short if it is lint.
I keep my keys in my pocket, so after a while, there is quite a bit of dust/lint build up.
When I change the battery, I try and blow out as much dust as I can.
Try another battery & clean out the inside terminal area as per Kika. Just because it was in a sealed pkg, doesn't mean its a perfect battery. With anything electrical, there is a very, very small, but finite possibility of an early death of a component (see "bathtub curve").
