Rennline Track Mat Quick Help
So I'm installing a full race track mat in the driver's side. The problem is that the mat will not lay flat because of a small stud welded to the frame rail. You can see this stud in the bottom right corner of the first picture. Am I supposed to grind that off? It seems wrong to leave it there as is.
-Beau
-Beau
-Beau
-Beau
Did you order the rennline track mat for the 993? Mine came with a hole there for that stud. It's what holds it down. Mine doesn't have the two other holes yours has. I think you have the wrong one.
A hole in the mat would be a hell of alot more reversible then cutting the stud off, and it would securely hold the mat in place. Seems like a win win to me.
-Beau
-Beau
Chad
