Roll Bar In!
Roll Bar In!
I just installed the Das Sport Roll Bar I bought from RLer Pete Pressley.
I am putting the other parts in now and will post many more pics soon!
Thanks again Pete.
Thanks again Pete.
I am happy to have the adhesive removal finished. That was such a time consuming and unpleasant process.
Did my one 10 weeks ago ...
final result was a step by step approach ...
MEK pre-loosening
Gasoline as main solvent (stays longer that MEK) but residue is a spread cluing film over the whole area...
MEK as post treatment
took a while but after figuring out how to do best, it was a reasonable effort!
What did you use?
MEK pre-loosening
MEK pre-loosening
I mostly disliked the fumes/respirator because it made it hard to work more than an hour at a time.
I am also tall and the interior of the car minus all the soft materials is a harsh environment to work in.
I ended up rewrapping the wiring harness tape too. That wasn't bad.
Yeah, respirator and heavy duty cloves are mandatory with MEK (it eat my 'usual' gloves in seconds).
I placed a big van on the (working) side door, blowing all the fumes out to the other side. That helped a lot!
