993 Forum 1995-1998
Alternator rebuild 993
Old Dec 23, 2013 | 10:54 PM
JB 911's Avatar
JB 911
These guys are visual! If you can post a pic I guarantee you'll get a response. I've read something like this before, I know you are not the first one to do this - sorry I can't be of more help...
Old Dec 24, 2013 | 07:18 AM
Garth S's Avatar
Garth S
Originally Posted by benjr
Ok in removing the alternator I came to the realization that I am a complete %^%## moron. I stripped the alternator shaft with a torx. A triple square wont even fit now. How do I get it off ? Split the nut off seems easiest??????
I would squeeze the span of the alt belt together sufficiently to secure it , with engine in gear: hold the 24mm wrench firmly & strike sharply ..... the nut should release. A 'tourniquet', or even a 'C' clamp can torque the belt.
Old Dec 31, 2013 | 12:56 AM
benjr's Avatar
benjr
i finally got it off but had to resort to cutting the belts. Once I got it off I was able to hammer the 12 point in enough. I put the alternator in my sawhorse and had to put a tremendous amount of pressure on to. It felt like it was on as tight as a head bolt.
Now another problem, in trying to remove the fan which is stuck on like a mother I accidentally dropped the alternator and fan. The tip of one of the fan blades broke off. Ebay for $ 150 0r have it welded and polished. I'm going to have the blade powder coated anyway.
Old Dec 31, 2013 | 10:36 AM
axl911's Avatar
axl911
If it's any consolation, I broke several things (additional $$$) while trying to get the alternator in and out. AND put a big *** scatch on my rear bumper!!!
