993 Alarm
Hi Everyone,
Seems like an never ending topic with the 993 drive-block removal - My 993 no different to that.
I finally managed to get the driveblock removed by changing the chip in the DME and getting the bypass relay.
All good and drive-block is removed.
My only issue now is that I would also like to remove the remote keyfob. I only have one and worried that it may break one-day. With drive-block removed I cannot program any new one, and since I am not the first owner I only have one key-fob.
Any quick ideas on how to remove the need for using the keyfob?
Whenever I unlock my doors the alarm goes off and I cannot disable it again unless I press the key-fob.
Maybe there is a special unlock procedure I can use or even better just remove it completely?
