Passenger airbag connector
I was able to remove the airbag, but...
I have read about the resistor trick to avoid the airbag light, and would like to attach the resistor to a connector like the one in the attached photo of my airbag. It has a Siemens part# which is tiny but looks like PBT-GF30. Usually Google is my friend for such things, but so far I have come up with nothing that resembles this piece. Any suggestions?
seems easy right?
after taking apart the insert side(in your pic) I couldn't even find the square connectors on mouser.
I gave up and just cut and soldered the resistor.
best of luck to you.
I'm really trying to keep all my mods reversible, so I'm reluctant to cut any wires. I've started emailing Porsche salvage companies, hoping that there isn't much demand for deployed airbags and therefore that they might have the connector available from totaled 993s.
Would this be a good option if wanting to add in an airbag on/off switch? When switch is on, it goes straight to the airbag, and when off it goes to the resistor? What kind of resistor is needed?
A few of you asked for further info on my passenger airbag delete project. This is what I did.
While not necessary, I wanted to avoid cutting any of the stock wiring on my car. I was unable to find the airbag connector as a separate piece so I sourced a used (deployed) passenger side airbag from a salvage yard, then cut the wiring off the airbag. (See photo 1) I also purchased 2.8 ohm .25 watt resistors online. Finally I made a quick trip to Home Depot for heat shrink tubing. Tools used for this included wire strippers, a soldering iron, and a heat gun.
Before proceeding, I disconnected my battery to minimize the chances of an accidental airbag deployment, which I'm sure would be no fun at all. In fact, my battery remained disconnected for a couple of days before I started any work on the airbag, though I've read 30 minutes is the minimum one should wait.
The next step was to remove the airbag. This isn't too difficult, but does take some time since you have to remove the airbag cover which in turn requires you remove the lower dash. This wasn't extra work for me since I was also doing a lower dash delete and installing both the Rennline lower dash cover and the Rennline airbag delete cover (both great products BTW).
Lower dash removal instructions are here: http://www.rennline.com/PDF/da70_install.pdf Two of the bolts are very difficult to get to.
And airbag delete cover instructions are here: http://www.rennline.com/PDF/da69_install.pdf The lower fasteners for my old cover were really torqued down, and despite my best efforts to avoid it, I did end up stripping the head of a screw, which then required that I grind the head flat on one side so I could extract it with pliers.
I didn't find any instructions for removing the airbag online, probably for liability reasons, but it was also fairly easy, requiring the removal of six Philips head fasteners and the wiring connector.
With the airbag out, it was time to assemble and install the resistor. There are several ways I could have done this, but I wanted to keep as much wiring intact as possible in case I had to do further work on the part in the future, so I left much more wire than I needed. I slipped shrink tubing over the wire, then soldered a resistor to the wire ends. (See photo 2)
Next, I rotated the heat tubing so it would cover the resistor and the soldering, and applied some heat. (see photo 3)
Time to connect the resistor (See photo 4)
Reconnect battery. Now the moment of truth. Engine cranks, and.... NO AIRBAG LIGHT! Yes!!! (See Photo 5)
That sticker attached to it kinda looks like "don't steal tampons". Glad you were able to make it work. I want to remove my passenger bag or put in a switch so my daughter can ride in the front seat in a booster as opposed to the back.
Having my daughter in front was also part of my motivation to do this. She has decided the 993 is her car.
Hey, Scott.
I just emailed DC, Weekend Rides, and LA. Weekend Rides said that they just chunk them. DOH!
Let me know how much you need for one of the resistors. I'll PP you the money for it and S&H. THANKS!
Did you get the E-Brake yet?
http://www.oklahomaforeign.com/
No charge, PM me the address and I'll send a couple of the resistors your way.
