993 Forum 1995-1998
distributor part question
Old Oct 18, 2013 | 04:00 PM
jhg41977's Avatar
jhg41977
Default distributor part question
Inside the shaft the rotor attaches to, one side has a felt plug, the other does not. I cant find a parts breakout for the distributor, so not sure where to get one, what it is called or what the part number is.
So, is it "important"?
Old Oct 19, 2013 | 01:58 PM
bcameron59's Avatar
bcameron59
AFAIK there is no parts detail for the distributor, certainly not on PET/Katalog. Maybe one of the RL gurus has access to Top Secret Porsche or Bosch manuals with more detail?
I'd find a piece of felt from something else (eg liner for winter boots or old hat) and punch out a piece using short piece of metal tubing of same or slightly larger inside diameter. The felt on my secondary is about 1/4" thick, the primary about 1/8".
Is it important? FWIW, here's a thread that discusses the purpose of the felt pads:
https://rennlist.com/forums/993-foru...-felt-pad.html
BTW I just did the belt replacement last night and it was fairly easy. If you are doing this, doesn't hurt to order 2 of the copper pins to replace the one you drill out on the main shaft. I did, as I was concerned I might mess up on re-insertion. Sure enough, the first pin went rolling under the workbench into a dark, inaccessible place beyond the reach of my arms, inhabited by spiders standing guard over non-ferrous parts that cannot be retrieved with a telescoping magnet.
OT, how's the reassembly on the rest coming along? Any luck sorting out all the seals and gaskets?
Cheers/Brian
Old Oct 19, 2013 | 02:25 PM
nine9six's Avatar
nine9six
Nice description Brian...Who hasn't BTDT. I had to laugh out loud over the spiders standing guard...
Old Oct 19, 2013 | 06:29 PM
jhg41977's Avatar
jhg41977
Spiders.....I have a truce with them. I dont go near them and they dont go near me. Thankfully I live in New England where nasty spiders are rare.
Thanks for the info, I have some felt somewhere.
Brian, I had Exotech replace the belt since they had my heads anyway. I usually order extras of parts but for the engine rebuild I didnt. I should have. So far I have torn #8 bearing oring, resulted in a day delay. This morning I noticed I am short a case through bolt washer, will have one tuesday. That is just this week. Im ordering doubles of all from now on and offering whats left on rl.
