2 batteries dead in 1/2 hour???
Car started as per normal yesterday AM. Drove about 5 min when Antilock, ABD and Airbag lamps come on. Car continues for 10 more blocks and engine begins to flutter, no turn indicator, hitting on only several cylinders then dies. I manage to coast through a hair raising left turn in traffic at 1 mph and coast down a hill. Start on compression. Get 8 more blocks and slowly die again coasting into a safe spot.
Car exhibits characteristic rapid clicking sound when I attempt to start. All belts intact. Fresh battery delivered to car. I start just fine. Continue for 5 more min. to destination.
Get in car at 2AM and drive for 5 min then again enter electrical hell. Antilock, ABD and Airbag come on. 4 min later radio illumination starts flashing on/off at random, dash illumination begins slow steady dim. As I pull into garage headlights are flashing on/off irregularly. Car now dead again.
That's 2 batteries killed in 1/2 hour of driving. Any ideas?
Many thanks,
-rb
Many thanks,
-rb
No ability to measure voltage during this little scenario. But yes, alternator is the obvious culprit but shouldn't the alternator warning light come on? It never has.
Out to garage.
I just now checked the warning lamps. When I turn on the ignition all the warning lights turn on except the alternator warning lamp. Burnt out warning lamp?
I was surprised by how fast the battery was pulled down though. I'm contemplating the wisdom of recharging the battery and attempting to reach my shop.
Thanks for your responses
Out to garage.
Good luck.
Quadcammer... that's a strong possibility (second battery quasi-funky). Of course I never marked them new /old at the outset several years ago and they both look brand new. I also am not in the habit of being dutiful about the warning lamp operation check at startup. Maybe this'll make an impression. How many of us actually check that christmas tree at startup?
Looks like Triple A tow to the shop.
Thanks guys.
-rb
Thanks guys.
-rb
Get a cheap digital multimeter at Sears ($20) and check the resting amperage of the battery and the charging amperage (while the car is idling). Really simple test -- will tell you what you need to know.
Besides not being charged, the battery you installed, if fully charged, should have delivered 120 minutes of use. Its called the Reserve Capacity of the battery specification. My alternator belt failed and my relatively new battery got me home from 110 miles away.
Install a voltmeter and forget the rest of the bling.
