Monoballs wrong way...
King of Cool
Hey guys,
Just another "adventure" with me buying parts and then letting them sit in a garage for a year(s) before installing...![banghead](https://rennlist.com/forums/graemlins/banghead.gif)
Bought a set of a-arms with monoballs installed a while back and finally decided to mount them but realized a snafu with the a-arms and how the monoballs are installed... Luckily I checked before I took the old arms out.
Can you spot what's wrong?
Now it's time to start heating the arms and hopefully can get these things out and turned around...
Any tips? Just blowtorch and trying to be gentle?
RL Technical Advisor
I would NOT heat them unless you can positively confirm that the monoballs do not have PTFE liners (high-end ones do) otherwise you will ruin them.
These should be carefully pressed out and re-installed the same way.
King of Cool
Thanks Steve, much appreciated.
I wanted to post as I wasn't sure, good to know they can be pressed without heat.
These look real good quality but I have no way of knowing whether PTFE or not.
