Need Bluetooth recommendations
Need Bluetooth recommendations--ALL DONE, THANKS!
I have the Becker/Harmon-Kardon TrafficPro installed, with a Sirius played attached to the AUX input via RCA jacks. I would like to have Bluetooth connection to the TrafficPro, in which case I would ditch the Sirius if I could stream Pandora. I would also like to make/receive phone calls via my iPhone 4S.
Any recommendations would be appreciated.
I just installed one of those. Awesome unit. Brings the car up to modern day standards for music/bluetooth/phone integration. Easy to use. Customization display AND key colors to best match the interior of your car. Easy to use. I was so glad to chuck the cassette unit in the car.
I want to keep the Becker/Harmon-Kardon TrafficPro, and just add streaming music via Bluetooth from my iPhone 4S.
This looks to be the trick--has anyone tried it?
http://www.discountcarstereo.com/BLU-BKR.html
The link to the "BLU-BKR Bluetooth Audio Streaming Kit for select Becker Radios" you have in mind seems to do the trick. Haven't done it. Just changed the main init... I prefer to have more source options like USB, Aux, SD card, Bluetooth streaming and CD, as well as the radio... I use a separate Garmin unit for the GPS part ;-)
BLU-BKR Bluetooth Audio Streaming Kit installed, works a treat!
Details here:
https://rennlist.com/forums/993-foru...-solution.html
Details here:
