993 Convertible top problems
Finally was able to remove the motors. The thin metal trim piece above the gearbox (when the top is fully opened) had to be unfastened and tipped slightly. I did not break the bond between the trim piece and the top material.
Upon opening the gearbox, a broken tooth was found on the helical gear. Will now rotate the gear as suggested in other Rennsport posts, and see what happens.
