Help!! - 993 Will Not Start
My first issue with the car and it sounds like the Start Relay however has anyone ever experienced shutting off the car and then it not starting, wil not turn over, just lights in the dash, turn he key and the driving lights dim but that's it.
1. Battery is fully charged.
2. I changed out the DME Relay (No Change)
3. I pulled the Start Relay but there is no way of knowing if it is defective unless you have another to put in it's place to try it which I didn't!!
4. Start Relay ordered - deliver on Tuesday next week. . .
5. Show-N-Shine Sunday
Any ideas on anything else to suspect?
Lloyd
8-16
Lloyd
8-16
Seared
The original battery ground straps are known to cause issues (within the mechanical crimp at the battery post). If your 993 still has the bare wire ground strap, I'd consider installing a new one. I believe I paid around $10 a few years ago from Sunset.
Andreas
Andreas
Lloyd, sorry to hear that, bud. Why is this happening on Friday afternoon's this summer? Two other folks posted no-starts on Fridays this summer.
Do you hear a click from the starter solenoid?
You're in luck if the Show n Shine is at your place!
Lloyd ..... shoulda hung up when you got it to start - I was ahead of the game at that point.
For more solid advice, hire a tow truck to get to the show & shine ...... fire trucks are more expensive & draw excessive attention.
Kurt,
Try googing "Location of starter relay for Porsche 993"
Without me even trying, I'll bet you get your answer
@ Lloyd
So much for one of the spare, "must carry items", no Porsche should be without.
@ Lloyd
There are seven (7) identical relays in the CE panel [ grey, 4-pin, #53 on top] that can be the spare ..... pull the horn & swap, etc ---or use the horn location to test a suspected relay.
Thanks everyone,
I still have not found the source of the problem however I am narrowing the field. Garth, I like your suggestion of the Tow Truck however I am skipping the S-N-S maybe this was my way out. . . sure hard on the back though. . .
Do you know the location of the Clutch Switch Alex was referring to? I expect under the floorboard however I will do a search.
Thanks for all the advice so far everyone, much appreciated and why I come here so ofter, hope I can return the favours in th future. . .
Cheers
Lloyd
Cheers
Lloyd
Sure enough, the lights went out when I started my car, so it is not an indication of a heavy current draw or a weak battery.
Thanks everyone,
Cheers
Lloyd
Cheers
Lloyd
The clutch microswitch is not your problem( good suggestion, however unlikely related to the 'smoke' issue you experienced) .... but to test if one is installed in your car, press in the clutch and bump the starter as normal ( immobilizer off, etc). Now, repeat the exercise with the trans in neutral and clutch engaged .... if the starter solenoid bumps, you do not have a functional clutch switch ( & vise versa).
Back to your issue .... after swapping starter relays during our phone link last PM, the car started and ran as normal ... for mere 10's of seconds ( thusly my comment above about not hanging up the phone quickly enough) before smoke emanated from under the left side of the steering wheel.
The subsequent pics you emailed do not indicate any damage to the starter switch wire harness .... so please pull off the round multi pin connector and examine for damage: trusting that none will be found, my thoughts remain centered on a faulty ignition switch: the prior relay swap between horn & starter on the CE panel that resulted in the car starting was a merely fortuitous red herring - as both relays functioned in the horn slot! - ergo, the ignition switch.
To that end, I will have in my hands tomorrow a spare ignition switch and the special, micro mini Phillips ratchet tool required to remove such a switch!! ( setting up a Sporting Clays tomorrow AM with a buddy that has had too many switch failures in his '89 SC).
If one had a spare switch in hand, then by simply pulling the harness off your switch and plugging this spare in - one could test for starting by twisting it with a screwdriver while hanging under the dash, bypassing the existing switch. Use the key fob as normal to deactivate the immobilizer, and the car should start being none the wiser to this Rube Goldberg set-up.
If it starts & runs without clouds of smoke, use the ratchet to finesse the two screws out of the back side of the original switch ....... and install this spare.
Sound like a plan? If you have already solved this problem, tell me now before I go on to conclude something really stupid
Garth,
Thanks for all your wisdom! It worked, The spare switch you provided had me driving around the block with a huge smile on my face, I hate electrical issues, they can come from anywhere. Hopefully this is all there was to this but once we install the new one I ordered then we can test other circuits to make sure there is nothing amiss.
New switch will be in Wednesday at 3:00 according to Porsche of Halifax, if they are right I will be amused and happy and be on my way to the valley to donate my 993 for a couple of weeks exercise. Hope you enjoy it!!! Looks a lot like yours. . . . will drive as good soon with a couple of strategically placed pins!!!
Thanks everyone for all your interest and help to resolve this issue.
Cheers
Lloyd
PS: Nice Wheels Garth!!!
Cheers
Lloyd
