993 Forum 1995-1998
P1411 code
Old Aug 8, 2013 | 10:42 AM
ferik's Avatar
ferik
Default P1411 code
Hi all,
Driving to my last autocross, on the highway in the morning, after an hour or so, I got the p0410 and p1411 codes with a Check Engine warning. I stopped and what I quickly read through my phone pointed to a small issue I could ignore for now.
I did that so well that I forgot about it and yesterday after a bit of highway driving (as opposed to normal around town driving), I got a P1411 (without a P0410).
Do you guys know about this issue and what should I do about it?
Cheers,
Erik
Old Aug 8, 2013 | 10:49 AM
XavierLaFlamme's Avatar
XavierLaFlamme
Have a look at threads that address the SAI system. My non-expert advice says that your problem starts there.
--Michael
Old Aug 8, 2013 | 11:01 AM
cabcoh1's Avatar
cabcoh1
6th Gear
Yup. Secondary low flow codes for cylinders 1-3 (P0410) and cyl. 4-6 (P1411). Blockage in secondary air plumbing and passages in cylinder head and cam housings.
-Charlie Burke
Old Aug 8, 2013 | 11:17 AM
il pirata's Avatar
il pirata
There are a number of threads on this if you search P1411.
Here is one with some good suggestions on troubleshooting.
https://rennlist.com/forums/showthre...ferrerid=93689
