Euro side blinker light mounting information wanted
Can one of you Rennlister's in Europe pop out your side blinker light and measure and diagram the diameters and positions of the 2 holes in the fender for it please?
I want to install one exactly like Porsche did on my USA car.
Thanks.
Thanks.
NO the wires are part of the Euro wiring harness.
The easy way is to wire them into the harness in parallel at each of the front blinker lamps.
The way Porsche did it was with a short harness that goes through a grommet up to the area next to the HVAC unit on each side. This harness is connected to the main harness and the central electric unit at the rear (go figure, why not front?) blinker wire connections.
All I need to know is the diameter of the two holes and the distance between them.
The distance between the holes as measured between the arrows shown here: O<-->o
Not the center to center distance which I can calculate from the hole diameters.
I know the other measurements to position the holes on the body.
The position of the edge of the larger hole was 83mm from the edge of wing/fender when measured along the horizontal centre line. This might help confirm your known dimensions.
