993 Forum 1995-1998
Bilstein hd shocks questions
Old 07-26-2013, 08:19 PM
nile13
nile13's Avatar
HD stands for Heavy Duty. However, things get more interesting from there.
In US Belstein has HD and Sport shocks for most cars. They are valved the same. The difference is the actual length of the shock. HS is used with stock springs, Sport is used with lower springs. In Europe, the same shocks are named Sport and Sprint. To make things more confusing, US Sport == Eu Sprint and US HD == EU Sport. Since 993s have adjustable perches i guess Bisltein, in their infinite wisdom decided that HD is a fine designation for a 993 shock. Possibly because it's the same body length as original Monroes and Sacks? I'm not sure.
Old 07-27-2013, 12:04 AM
zenithblue993
zenithblue993's Avatar
Good insight thanks!
Old 07-27-2013, 02:41 AM
Falcondrivr
Falcondrivr's Avatar
Yes, the bilstein HD have extra threads so you can lower your car if you have the correct springs to do so.
Old 07-27-2013, 04:26 AM
Sean993
Sean993's Avatar
I had the bilstein hd's on my car, till a couple of months ago , when I switched them for the koni fsd's. The bilstien's have sharper handling, but the harshness is hard to live with, not as bad with 17 in wheels. As for ride height only the front struts on the koni's are adjustable, but that is all you need if you use M030 or M033 springs, with one degree of rake the height looks perfect, I am in South Tampa near Hyde Park Village if you want to see for yourself.
Old 07-27-2013, 12:15 PM
Falcondrivr
I am too! The three of us should get together so he can compare ride. Mine are the BilsteinHD and M030 springs. As harsh as I could stand in South Tampa.
Old 07-27-2013, 01:31 PM
Sean993
Sean993's Avatar
We could meet near Davis island airport, there are a few corners there, Ill pm my number
Old 07-27-2013, 02:10 PM
zenithblue993
Ya that sounds like a good idea!
Old 07-27-2013, 04:03 PM
pp000830
pp000830's Avatar
Received 1,535 Likes on 1,084 Posts
The H&R kit includes springs and I believe
4 Bilstein shocks valved to match $1900 on ebay. Inexpensive and get the job done.
Old 07-28-2013, 12:28 PM
M. Schneider
M. Schneider's Avatar
My opinion and nothing more, I'd say start by investigating the Koni FSD technology. Cast around for a 993 owner in your area who has lived with these newer FSD dampers. The FSD/M033 equipped 993 I drove for about an hour (in Germany) was compelling; Street/sport use with a DE thrown in for good measure. There's plenty of VW GTI MkV chassis owners (GymKhana racers) who concur...
The performance of the USA Bilstein HD (B6) mono tube series has long been a benchmark in street dampers,, for decades - and has a life time warranty to match. Choices, choices... Door number one, NO door number two, NO one...
A M033/FSD equipped 993 is a desirable combination for street/sportif use.
But hey,, I'm just saying... Something to keep in mind is this, street ain't the track and vice verse.
Originally Posted by dmurchison
So is the konis better then the blisteins in your opinion?
Old 07-28-2013, 01:36 PM
nile13
nile13's Avatar
I think the only way to tell is to try. Luckily, there's a large enough and generous enough Rennlist community where you can almost always get a ride in someone's car with desired suspension, mods etc.
One word of warning. I'd mostly disregard the same shocks on different cars as base for comparison. As some examples, Tein makes very good suspension for Japanese cars that does not work well on European cars. Some say that reverse is true for Bilsteins. It boils down to how familiar the manufacturer of the shocks/coilovers with a particular model. Getting the rates correct is far, far from easy.
Old 07-28-2013, 01:47 PM
M. Schneider
Oh I second what he (nile13) said. It takes real suspension evaluation time, can't phone this stuff in, to get the best out of a chassis damper/spring set up..
... Never true'r words spoken. Drive the very car/application.
... EDIT/DELETE...
...It boils down to how familiar the manufacturer of the shocks/coilovers with a particular model. Getting the rates correct is far, far from easy.
Quick Reply: Bilstein hd shocks questions
