Help finding a part number in the sunroof mechanism
The screw in the first pic fell out. Can anyone help with either a part number or a spare one?
Looks like it might be part of the sunroof cable assembly. Anyone have the specs on just the screw? I'd hate to replace all that over just a screw.
Thanks,
Thanks,
Yeah, I have the PET. Can't seem to find just the screw in that. Seems like it might be part of #7 above, but I don't see it separately?
I wasn't very clear. The pic shows the bolt/screw still in pllace from the other side. The one that came off is the brass hex screw shown in pics 1 * 3, fitting horizontally into the bracket, not the bolts that fit vertically (#9).
Make more sense?
Make more sense?
Not really
maybe its a good idea to get just the M4x6 from the local iron-shop or construction market and try if it fits ...
shouldn't be very difficult to get such metric screw in the middle of New York ... !?
Maybe you even get one of the still existing ones out and use them as a pretty close sample... ?!
Bill...in the first and third pic it is the gold/brass colored flat head screw, hex head bolt. In the 4th pic it would attach horizontally through the bent washer shown connecting that silver L bracket to the brass looking piece. It slides with the sunroof, and seems to be attached to the cable and pin assembly.
Thanks Bill, but the bolts above are different, or at least go in a different slot. Those go in vertically to hold the bracket on the sunroof on the track. This bolt has a flat head screwdriver slot with a hex head. They go horizontally near the cable. See pic #1. Do you have the cable and the slider unit they attach to near the sunroof itself? You can see the bolt / screw in question attaching to the "T" looking bracket here:
http://www.autoatlanta.com/results.p...r2=96456414400
It seems to come only as a part of the assembly, I think #7 in the PET above, hence my challenge in finding it.
I'll send a pm
