SAI Check valve washer
07-09-2013, 12:38 PM
Check valve removal success
Now, washer or no washer???
I have read that some cars came with some without. Mine came with (build date 03/96). The replacement SAI Valve came without. Any recommendations? Part numbers? Or just anti-seize and install?
07-09-2013, 12:42 PM
maybe the valve had been replaced before?
looks like a standard oil drain plug washer.
07-09-2013, 12:49 PM
AddictLifetime Rennlist Member
If it was me....I would find an alum or copper crush washer and use that. Pretty easy to find. I don't see a reason not to.
07-09-2013, 09:03 PM
Even with the crush washer, I'd use some anti-seize on those threads.
07-09-2013, 09:33 PM
Quote:
Originally Posted by
k722070
exactly what it is, same as the oil drain plug washers
As other have said, I would use one
Makes it easier to remove the valve the next time
07-09-2013, 09:46 PM
MarkD
I used no washer but put Kopr Kote on the threads to guard against seizing.
Feels good to clean out the SAI doesn't it!
Michael
07-11-2013, 09:36 PM
It was such a pain to get out that I installed mine only "hand tight" when I put in the new one.
