Suggestions for 993 upgrades for HPDE
#31
Race911 - so you're saying that is not something I should consider, I assume? It's a reputable shop, or so I thought, they've given me a ton of headaches the last couple of times I've been there though which makes we want to find another shop anyway.
Has anyone else heard of removing the catalytic converter in favor of a straight pipe?
In terms of other upgrades, I think I'm steering clear of seats for now because of the overall cost of two seats, harnesses, HANs, brackets, etc.
#32
1) less weight at the extreme back end of the car
2) less heat
you do get somewhat better exhaust gas flow, how much is hard to say, but it's not big
it's more difficult to do this on the US OBD2 cars, '96 up
#33
If your state does emissions testing, you will probably fail without catalytic converters. Or you may not. But if you fail, it can show up on your Carfax.
After taking delivery of my car, I put the cats back on so it could be inspected and registered. I suppose I could've taken them right back off after getting my sticker, but I'd have to do that rigmarole every year come inspection time.
That's not worth the schadenfreude of my exhaust setting off car alarms in my parking garage.
#34
#35
This would be my list
- Track tires so you stick better in the corners
- Better brakes so you can brake later for the corner (optional). Periodic flushing is a must.
- Track experience so you know when and how to brake for the turn
- More track experience so you know when to turn to stay on the line
- More track time to brake/downshift/turn/accelerate as smoothly as possible
#36
^^^^ Where is any 911 brake compromised?
Not to mention one of the worst things anyone below mid-intermediate can do is run a slick/R compound/"DOT100" stock class autocross special tire............
#37
#39
ahh geez, if you guys are such pros and know-it-all why not educate instead of posting smart @ss comments. Not all of us are race car drivers here.
Didn't say the brakes are compromised and didn't say R compounds, but if you can elaborate why running slicks is a bad idea that would help.
my list is not in any particular order, so not sure what is bass-akwards
All I was trying to say is that more time on the track is the best way to improve along with best tires brakes you can have.
#40
Not smart *** comments - please don't be defensive. Between us, Ken and I have (sadly?) well over 80 years track experience. I (like several others who post here) race, hold several track records and still instruct as often as I can. More than glad to educate, as this is the only goal here - helping out.
The implication regarding brakes certainly seemed to be there. Keep in mind the fact that ALL of the stock classes race on stock brakes. Cooling helps, yes, and good fresh fluid is a must. Stock pads work well for a while, but race pads are a must in a race situation (heat is the issue here, not friction)
As a student advances on the track, brakes take less and less abuse. Braking becomes softer as corner entry speeds increase - we no longer zoom down the straights, slam on the brakes and then rinse and repeat.
99.99% of the students I instruct do not use the available grip their street tires offer, yet they still need the forgiving nature of same. While R compounds offer far more grip, they are very touchy at the limit and will let go far more quickly than the student can react (or "pro-act") - they also (more importantly) will mask driving errors and give the student a false sense of secutiry and accomplishment.
#41
Thanks KaiB. What about dedicated high performance tires a couple notches below the R-compound slicks? Tire rack seems to have a few choices or they all too hard core?
I was speaking from my very beginner experience. My street tires are old, not gripping that well and seemed to be the main limiting factor.
My brakes on the other hand are very strong (4S). Im not sure how much worse the base 993 brakes are, if at all. But as you mentioned pads should be considered. I wasn't necessarily saying one should go get a bigger brake kit.
#42
The general consensus seems to be when you are driving at the limt of your tires consistently, then you go to a better tire. For me, when I had the Dunlop Star Specs screaming at me on every corner, while 4 wheel drifting at 100MPH, I switched to Hoosiers... I still worry that it might have been too soon.
#43
For a beginner, I'm partial to the Dunlop Star Spec Z1, as I know the tire.
Falcon - you made the right choice. Proof is the fact that you can feel the increase in grease as your tire pressure comes up a pound of two above optimal on the R6.
#45
in front 993tt and 993RS ~2306n-m @70bar line pressure
in back RS ~874n-m, 993 ~751n-m, tt ~624n-m
brake bias and thermal performance are the biggest differences
RS has most rear and best overall thermal balance, tt has the worst
I'd certainly use a track pad Pagid RS 29s or PFC97s both work great
993RS is is one of the best braking cars you will ever drive
