Undercoat Touch Up
Undercoat Touch Up
My 95 has a bit of rash at the front of the trunk floor pan caused by a PO. I cleaned the spots up and etch-primed any bare metal, I now need something to touch-up the off-white undercoating.
I did some research and it looks like beige Wurth SKS Stoneguard was the closest match, however it appears that this product is no longer available. The only Wurth undercoat product in the current catalogue only comes in black. 3M Body Schutz was also mentioned but it only appears to come in black as well
Is there a product currently available that matches the undercoat on the 993?
Thanks.
Thanks.
The undercoating on my car is silver in color. I used Gravel Guard "Silverized" from Lordco. Not an exact match but close enough if you feather the edges. Probably can't tell after a year of weathering.
I used this product on a different project, they have a white.
http://www.herculiner.com/product_info.htm
Might be worth looking into, you can roll it on, and it *might* be tintable to match your coating. Once it dried it had the same look and texture as undercoating.
I use 3M in grey but the product number is different in europe from NAmerica.
Over here it is 3M 08879 (1 liter is 12 euros)
here is a picture
http://www.ebay.fr/itm/3M-STEINSCHLA...item4d0acca666
http://catalogue.3m.eu/en_GB/GB-Mari..._Coating~08879
here is a picture
