Do I need to carry a spare DME relay? (noob)
#32
Based on feedback from members, I also purchased a DME for mine. I bought it on amazon for under $30US. I took out the original one and put the cheapo in there. If it fails I have the "good" one in the furnk to back me up. I haven't owned my car for a year yet. It sure has been an interesting first year so far.
#33
How can you favor the old DME as a good backup when the old ones are prone to failure due to faulty soldering? You may want to rethink and use the new one as a backup. Just saying.
#35
The DME Relay is pretty easy to find, it's the one closest to the front right of the car (if you were sitting in the driver's seat). It also says DME on the top......
There is a big difference in price between a OE relay and a aftermarket relay, I have no idea if there is a comparable difference in quality but I doubt it.
#36
Read the link on the first page. I guess that taking it out and putting back in puts some force that can easily damage the original soldering. I'm not sure what's the exact logic, it just seems that some had an issue come up very shortly after taking the original relay out. And some who never took it out never had an issue...
#38
Since the new one has worked for a month, I may just switch it back. Makes sense if the other was older than I think.
At any rate, I carry a spare.
#39
There is really no risk in pulling out the old dme to test the new one. I pulled mine out countless times.
#41
#43
I take my DME relay out quite frequently. I take it out when changing the oil, to build up oil pressure before actually firing it up, and pretty much whenever the car has sat for more than 10 - 14 days (for the same reason). It's been removed/replaced better than 30 times I suspect, never had a problem. I fail to see how removing the relay is going to shorten it's life.
I'm sure it's quietly collapsing on itself as I write this.
#44
I'm waiting for someone to say, "I bought a back-up relay and then got worried that it might fail so I bought another one because if the one that is in the car failed and I replaced it with my back-up, I wouldn't have a back-up for the replacement. But then I got to thinking that the back-up to my back-up would fail, so I bought a third relay as a back-up for my back-up for my back-up...."
It is possible to overthink this guys....An old relay, in the car and working, along with a back-up relay will probably last you for years.
#45
100% agree, Terry.
