Misfire while accelerating
The engine idles quite well and drives very smoothly at slow speeds. Once accelerating, the engine misfires (misfires hard enough that it is easily felt in the car).
The distributor caps and rotors all look to be installed securely and are fitted correctly.
My question is: is it possible that I inadvertently switched a pair of spark plug wires?
If a pair of spark plug wires are switched, could the engine idle smoothly but misfire under acceleration at higher revs?
Thanks much.
A quick check will confirm proper location of wires.
You likely have two wires swapped. Since we have twin ignition, a swapped wire can be masked because the 'other' plug handles the combustion for the cylinder.
To narrow it down, with the car off, remove one of the coil wires at one of the distributors. Place the end of the wire so it does not arc to something metal when the car is started. Then start the car and see how it idles.
The car should idle reasonably well on either distributor by itself. The lower left belt driven distributor cap sends spark to the top plugs. The upper right shaft driven distributor cap sends spark to the bottom plugs.
Good picture with labels - credit to IXLR8: http://edelweiss.smugmug.com/Cars/Po...4492&k=p4Q9Vrq
The picture and comparing with your installation should be sufficient to see what's amiss. There ignition wires should have labels on them, but they are often difficult to find.
EDIT: Yep, Alex has you covered. His response was not present when I started replying. Sorry for the redundancy.
The misfire wasn't present prior to starting this project, so I am going to check the wires carefully. I think that is likely where I made a mistake.
So although the wires were correct at the distributors, plug 1 and 3 wires on the bottom side of the engine were swapped.
https://rennlist.com/forums/993-foru...ed-solved.html
For me, finding and fixing this resolved an infrequent misfire when making a long left turn from a dead stop.
