suspension squeak?
I pulled my 993 out of hibernation today.
i noticed that over larger road bumps the front shocks would squeak under compression?
The car was serviced and aligned by the dealer just before storage so I didnt get a chance to notice anything until now.
(49000km, stock suspension)
The ride height was 4x4 from previous owner and i told the dealer to drop it down to proper factory height. I still have lots of room between tire and fender so i do not think the squeak is the result of being too low. I am by no means euro ride height.....
Other then that, the car runs beautiful and i enjoyed every minute of my ride home.
993 owners talk about the stock Monroe's being shot at 25k-27k miles. I dont think the squeek is shot suspension as much as maybe dry bushings after a cold winter. Was your car stored in climate controlled environment or a cold garage?
(49000 kms = 30380 mi)
I also think it's more likely that the squeak is coming from the bushings, rather than the shocks....
Also, after 30K miles and 15+ years, chances are very very high that your stock suspension is tired and new dampers would transform your driving experience.
I will take a look at my bushing however.
thanks guys!
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
My eyes got like this
![EEK!](https://rennlist.com/forums/images/smilies/eek.gif)
I have H&R coil overs on my shelf ready and waiting
How about spraying some lubricant on the rubber to metal contact points under the car?
I would even consider shooting some lubricant on the damper & strut rods.
The TSB is available on Mike's PCAR workshop web site (http://www.pcarworkshop.com/images/1...996_640596.pdf).
Porsche advise to lubricate the bushes with Vaseline, so if yours aren't shot giving a lube might solve the problem.
