H&R Coilovers info request (pros, cons, how to adjust etc.)
I'm considering a 993 4S, and the PO installed H&R coilovers. Unfortunately there is no documentation on it. I did squeeze my head to see that they are there and have H&R stickers on them. The car is going for PPI next Tuesday, so I'm sure I will find out more.
A couple of questions:
How many types/models of adjustable H&R coilovers are out there that fit 993?
Could you please point to a good thread about H&R coilovers and DIY on how to adjust them?
I drove the car and was happy with the ride (very straight, firm, not excessively bumpy). The PO said the coilovers are in normal/not very aggressive setting, and I'm happy with it, but I would like to learn more about them.
Here is side view of the car, is it lowered? Normal height?
Appreciate any input on this matter.
At that height RS wheel carriers are very desireable
I recently installed the H&R kit - $1800 a significant handeling upgrade over the OE like driving a new and vastly superior car. Set the ride height somwhere between USA at the top end and ROW lowered value at the lower end will allow you to use the OE alignment specifications. The original drop links can be used so the only parts you will need other than the kit are replacement lock-nuts that hold the top mounts to the car body. The kit i purchased on ebay new was H&R kit number:29954-1
These are the current H&R options:
Standard monotube coilover: 29954-1 , stainless steel with black springs.
Clubsport: RSS 37-954, also available in non street approved track version.
The 40953 is a shock/ spring combo and not a coilover. It is similar to a Bilstein B6 HD setup.
the most likely reason the Cup shocks are not approved is that they were never submitted to the approval process or if they were they were too short to pass
The Cup shocks are much stiffer than is usual for street shocks and are valved for much higher spring rates. Additionally they are shorter than the usual street shocks so that the car can be setup racecar low, to set the car up that low requires RS wheel carriers and solid rear side mounts
stock they will jar your brains out, have them rebuilt w/ digressive valves to match the springs and you will have a well controlled but still very firm ride
In Germany all aftermarket parts have to have TÜV approval
Actually, H&R does show the RSS being TUV approved:
911 Carrera Typ 993 Rennen-NR-NS X RSN-37-954-1/1
Clubsport X mit/with TÜV RSS-37-954-1/1
My H&R kit was installed by the PO in 2010, it's # is RSS1590AA R/shock and monoball, included with H&R adj sway's #71953. While this is a discontinued set-up, and no longer supported by them(ask me how I know), they are still floating around FS in cyberspace.
My car came out of NJ also, H& R coilovers, seem to be on lots of 993's from there.
I am having the H&R PCS kit installed, 32954-1Like some of their other products, it's Bilstein dampers valved for H&R springs. These are similar to PSS10 so I get the damping adjustability. Thought about the RSS but thought it would be too much for street use. I may try car on track a couple of times. I'll post a review after I've had time with the car but I can't wait to get it.
