Wheel / Tire fittment advice
Hello,
I have done all the preliminary searches and read every post from Bill Verburg, but, surprise, still need advice, namely what size tires should I buy to ensure a less problematic fit for the following rims on my C4S.
Front: 9.0 x 18 ET 45
Rear: 11.5 x 18 ET 35
Also for your consideration, I am installing PSS10, and will roll the fenders as needed.
Thank you
Thank you
quick follow up....
also I am not adverse to running agressive camber
....quick correction, front rims have an ET of 47
will type slower next time
Hello,
Thank you
Thank you
in back a stock S used 10ET40, 11.5ET35 sticks out 24mm more and also intrudes 14mm further toward the chassis. Again I doubt that it will fit well.
Gentlemen,
Here are the very same rims on the PO's car. Seems like they fit. Am I missing something?
You will have to decide if you can live w/ them
The pic shows a car that is quite high and the wheels stick out quite a bit
Thanks Bill, upon closer inspection of picture you're quite right.
