QUESTION - Keeping the car powered while replacing battery
The battery of my 993 is shot. Due to pain to go through custom ECU adoption with LWF I would like to keep the ECU powered while replacing the battery. What is would you recommend?
If you have a Battery Tender or similar charger with cigarette lighter adapter, just plug it in. Otherwise, you'll need to put the alligator clips of the charger to the Pos. cable and Neg. to a good ground, making sure they don't disconnect while you pull the cables from the battery and replace it. Once the new battery is hooked up, you can disconnect the charger.
i think they have a setup that plugs into the cig lighter with a 9v battery.
https://rennlist.com/forums/993-foru...connected.html
http://www.walmart.com/ip/NOCO-Setti...ttery/16213367
I've used this for years on many cars. Works perfectly.
