Corteco motor mounts for 993-First review
I had asked about corteco mounts in this thread :https://rennlist.com/forums/993-foru...for-993-a.html
They hadn't been tried or reviewed yet.These are made by the original equipment manufacturer and only $91 ea and direct bolt in.
These had been used with success in the 964 cars. I got these from pelican and they are very reasonably priced when compared to factory c2 mounts. These of course are c4 mounts and are supposed to be slightly stiffer. I did not want to go with rs or wevo due to the need to reinforce the carrier and the loss of passenger comfort (depending on which review you read) since my wife and kids ride in the car. I had used wevo, sport and solid mounts in my prior 911s and knew that wasn't my direction on this car.
Photos posted show the comparison of the new c4 corteco and the old factory c2 mounts. Another shot shows both oem next to each other and one had collapsed internally allowing it to stretch. The replacement mount housing is thicker and sturdy appearing. The spacer for the c2 bolts topside is not reused.
Old and new
Both old with one blown and stretched out.
Wobble extension used to get to one of the driv side bolts on the factory mount
New installed 30 ftlbs top Bolts and 62 ftlbs bottom
I must say these do feel slightly more firm but after 30 seconds I couldn't notice any more. Surely very minor between c4 and c2 mounts.
Also I detached the latch cable and moved the guide tube slightly to wiggle out the driver side mount. I recommend you test the latch is functioning before you shut the engine lid.
Hope this helps someone decide if you weren't sure
Good luck
Old and new
Good luck
Thanks for the post. Looking at changing mine out. Looks like a reasonable alternative.
With RS mounts, do you need to do reinforcement? I was thinking about going that direction, but don't have any desire to do any reinforcing.
Your Corteco mounts at $91.50 from Pelican appear look a lot like my 'Porsche' mounts at $150.73 from Sunset. Difference in manufacturing date and '08' versus '09'. Mine went into my C4S.
some say that RS Mounts + track\hard driving would require the reinforcement.. I haven't and no issues so far.. not sure what it will be like to break a engine carrier and might be something on my project list.
phil.
phil.
From the picture it looks like the Corteco one's are a bit shorter between the top mounting surface and the square on the rod. If you don't use a spacer, your engine should sit about an inch or so higher then before.
I purchased turbo mounts for my C2 and I had to install a spacer to make it all fit right.
Just an observation. I might be wrong I just know the difference between the turbo mounts and stock C2's. There's a difference on those as well. The turbo mounts are much firmer and they can't leak!
Ed
Ed
The spacer is normally on the topside of the mount but the c4mount is much thicker casting and makes up the difference of the c2 stamped steel. Hopefully you can see in the photos. Any one that goes from c2 to c4 mounts can probably chime in here. It doesn't space the mount but just the bolt.
Ed
Ed
Technical Guru
These are made by the original equipment manufacturer and only $91 ea and direct bolt in...I did not want to go with rs or wevo due to the need to reinforce the carrier and the loss of passenger comfort (depending on which review you read) since my wife and kids ride in the car. I had used wevo, sport and solid mounts in my prior 911s and knew that wasn't my direction on this car.
Corteco is the aftermarket marketing division of Freudenberg who is the OE supplier to PAG. They sell two versions of each motor mount, the more expensive is the hydraulic version that is exactly like what our cars were delivered with from the factory and the cheaper ($91) version are solid rubber. Which is exactly like the RS and Wevo mounts! The durometer is not exactly the same but you are basically buying the same thing.
