DIY - Changing the SAI Check Valve
#46
Being a newby to the 993 and after reading a lot about the valve, wouldn't it be a good idea to consistently use 93 gas with techron in it or am I missing something?
Chuck
Chuck
#47
![thumbsup](https://rennlist.com/forums/graemlins/bigok.gif)
#50
But you don't get the neck snapping power of the varioram set up either.
![ducking](https://rennlist.com/forums/graemlins/icon107.gif)
#51
The 991 PDK SC is faster, but the 993 has nice power. The last old one I owned was a '74 and that one was truly a snail.
Chuck
#53
Updated: 4-18-15
What’s New
Added sealing ring to SAI check valve.
Materials Needed
SAI Check Valve 993-113-250-03
Sealing Ring 900-123-118-30
Removal
Take care to not loose the sealing ring under the check valve.
Installation
Apply some copper anti-seize paste to the threads.
Place the sealing ring carefully onto the check valve port of the SAI manifold.
Updated: 4-18-15
What’s New
Materials Needed
Removal
Installation
Thanks, JB. I knew the CEL wasn't an issue with the '95, but I didn't realize the SAI was a total non-issue.
The SAI system acts as a bellows for quick heating of the cat. If the system fails due to clogging, the cat still heats, albeit slower. IMHO, it was senseless of Porsche to employ the feedback in 96 via the OBD II iteration, but I think we can all thank the EPA for mandating of the OBD II.
As I understand things, the 95-98 Pcars, can be in a perfect state of tune and running fine with the SAI ports clogged solid.
#54
Re the sealing ring, the 993, 986, and 996 all use the same SAI valve. However while the PET for the 986 and 996 show the sealing ring, the 993 PET does not. The air distribution housing that the SAI valve screws into for the 986 and 996 is a 996 part number so must be different from what is in the 993. Bottom line - is the sealing ring necessary for the 993 or only for the 986 and 996?
#55
Also, FWIW, the PET is not known to be 100% accurate.
#56
When I removed the original factory-installed SAI valve on my '96 C4 I found a sealing ring. I replaced the sealing ring along with the valve.
Same here
#58
Lifetime Member
Lifetime Member
BTW, Pelican sells a SAI DVD & kit. The kit consists of a Snap-On crowfoot machined to fit nicely under the valve along with a sai valve adapter with an air fitting to hook up to your compressor after injecting the de-carbonizer down the adapter. The P-Car guys are the ones doing the SAI operation..........they have they own site at www.p-car.com.
I had my SAI valve replaced at 42K miles, and it was a corroded mess inside. Planning on doing it again soon as I am at ~65K miles. Just need to get the crowfoot, as I am now in DIY mode. Just passed smog again with flying colors, numbers even lower than 2 years ago.
#59
The SAI replacement DIY is no longer on the P-Car.com site,
#60
The DIY written up in this very thread is far easier to follow than the pcar one...just saying.
The Pelican SAI kit is good because it also comes with a screw on air compressor hose connection for cleaning out the passages along with a very high quality SnapOn crow's foot that's modified. Will make future SAI services a breeze!
