Anyone make a rear center muffler?
I am running cat bypass pipes now, but was thinking that a rear center muffler that bolts to the HE would be a clean set up.
Anyone have this or know if someone makes a rear center muffler for the factory HE?
TIA
TIA
The main issie is the stock headers outlet pipes are very close together so no room for pipes and a muffler. I have a center outlet on my car but use a set of fabspeed headers which have the outlets a long way apart.
When I had my turbo kit, I used a Magnaflow 5”x8” muffler (#12468). It sounded absolutely awesome. I loved it. It uses an internal x-pipe layout, so it shouldn't be too restrictive. Here's a pic, but obviously you'd need different piping from the heat exchangers. As you can see, the muffler tips present a bit of a challenge for the installer. Mounting the muffler is fairly simple, just need one custom-made bracket then a stock 993 muffler strap.
![](https://rennlist.com/forums/attachments/993-forum/330711d1232724347-protomotive-stage-1-twin-turbo-install-diy-cptmufflerwork002-resz.jpg)
