Mobil Delvac 75w-90 Source
Gentleman,
For my upcoming tranny fluid change, I needed a gallon of M1 Delvac.
The typical source is lufteknik or LN Engineering.
Luteknik offers it for $42, but the shipping was $34!!!! (see edit) and thats ground!
LN wants $80.
Well, I found a place that delivered it to my door for right around $50.
http://www.zorotools.com/g/Gear%20Oils/00065928/
Shipping is free over $50, so add a few household items for the extra $3.
Also, found a $5 coupon code, so basically $45 shipped
EDIT: seems my shipping was inflated due to order a few washers...how that adds $19, I'm not sure.
LN wants $80.
I could not believe it.
edit: ok, so after checking again, its $15.
I had a few washers in the order the first time. I can't believe that this would jack up shipping by $19, but i guess anything is possible.
Received 5,404 Likes
Good price.
If you do the tranny and the diff, you'll need slightly more than 1 gallon.
You can't beat that. Its even tougher to find up here as its only available in 20 litre pails through the one bulk dealer in town at $180. Shipping from Lufteknik or anywhere in the US (via ground) is out of the question.
Same here in Calgary, can only buy in bulk. Sometimes I ship to Montana but that is expensive for oil for what ever reason.
We just buy the 20l and share it among friends. (I need enough for 2 fills as I will probably going into my transmission after the engine is back together.)
Well, I found a place...
For the gentle life my 993 leads, its not an issue, but I'm wondering what the huge difference is between Mobil 1 LS that I use and the Mobil Delvac, considering the numbers in Bill 993's post in a recent gear oil thread.
QC, thanks for that. Its been bookmarked and I found leads to products that I have been looking for, for a while.
I've run delvac and been happy with it, but there are plenty of other options, including LS that seem to work fine. I say use what you like.
Gents,
Best place to find Delvac in jugs is HD Parts Distributors that cater to Over the Road Class 8 fleets although pails is the primary volume seller in our industry.
Point of interest on the "robustness" of the Delvac product. Drain interval recommendation by Roadranger Transmissions (Class 8 trucks) is 300,000 miles!!
Another way to do it, for a great price, is to team up with another local Rennlister and buy a case for $158.00 (39.50/gallon) and split it 2 gallons each:
www.thelubricantstore.com
Under "Commercial Products" then "Gear Lube".
Guys you should use the locator on the mobile site also. Carter machinery here is a dealer and you can get a case of quart bottles for easier split up between friends. If you happen to know some one in truck parts and get a discount it's cheaper than some other options. I'm actually considering motul gl5 or ams oil gl5 now though after hearing some easier cold shift reports.
