AC Evaporator Replacement Time
Just to get an idea, I got a quote from a Porsche dealer in the Bay Area. The total cost including parts, labor, freon, etc. was around $3500. The evaporator alone was $1800, not $1000.
Georj
Georj
I am also in need to replace my AC Evaporator. Been reading up on all the threads and information....
I'm still not 100% sure which replacement evaporator I should use and why??
1) Original factory one
2) Kuehl Serpentine Evaporator
All comments and information is truly appreciated ! TIA
'97 Blk/Blk C2S
'97 Blk/Blk C2S
'97 Blk/Blk C2S
'97 Blk/Blk C2S
Emerald
You have to disconnect the fuel pump from the tank. No other way to do it. Believe me, this is one of the easier steps. Make the investment in tools to lift car. I would also recommend replacing the dryer since the system is open and cleaning the condenser coil while the wheel well is out. Do not use high pressure on the coils. Just use domestic pressure no more than 80 psi and a degreaser like simple green. My condenser was filthy.
Why not first try a product to stop the leak at the source?
I have had excellent results with Enviro-Safe products
http://www.es-refrigerants.com/produ...l4/details.asp
ProSeal XL4 is designed for repairing leaks in condensors, evaporators, copper line, and solder joints.
This product is an epoxy that reacts to water and air. When coming in contact with the atmosphere, it forms a seal over the leak.
If your system stays charged for one day when running, this product will fix most leaks that you may encounter.
The issue with Behr (althou original) is the two dissimilar metals been welded together (copper and alu) there where the leaks start. The best evaporator for the price is(ACM $150.00) is an all aluminum unit, which it is much more efficient since iit is all alu., the other one is the serpentine type which it is good but way to expensive at around $500.00, I have done a few of these ($150.00 ones) replacements without a hiccup.
Is the Keuhl version and Keuhler?
Any valid reason to go Keuhl over ACM?
Sure not going back with OEM...
Denny
