tarret toe links
Guess it depends where you're coming from. On SMOOTH pavement (nearly non-existent in CA), I didn't find the yellow car uncomfortable at all with zero rubber in the suspension + 3-4X OE spring rate + RA1s + Recaro shell with zero padding.
Communication between the car and road is a two way street, anything that nails down your inputs will also echo what the road is saying.
On bad roads there will be a lot more feedback into the chassis, some find this disagreeable.
