Is there a trick for reading the oil level on the dipstick?
#61
Even though I know what you mean (illustration of a point) I wouldn't make a general practice of leaving your lube system down three quarts. There is no question that it wouldn't have any effect on oil pressure but even though these engines are called "air" cooled, much of the cooling is provided by the volume of oil coursing through the lube system...more oil=more cooling. Cheers
I pour in 10qts when I change the oil, every time. When my gauge stops coming up at idle, I add about 1/4 of a quart.
My point with all this was that being fussy over minute differences on the dipstick is absolutely pointless given how much extra oil is in the system and its dry sump nature.
#62
Someone mentioned a napkin trick. Sounds like it might be what I do. I use a paper towel in one hand and spin the dipstick on it. Th oil mark left on towel will show the level.
#63
Wipe dipstick clean and dry, reinsert and lay on a shop towel for oil level.
#64
right, of course not. But if the difference between showing on the stick and being halfway is about .75 a quart, if the stick shows anything, you're perfectly fine.
Guess what, I'm never sure what my oil level is.
#65
Yes, personally I try to hit the mid point between HI and LOW during a change and don't add any until a full quart can fit (and still be close to mid range). I have an 85 as well as a 993, and both seem to use considerably more oil when you try to keep the level in the higher ranges of the dipstick. I'm not sure why these engines operate that way but anecdotally many guys have experienced the same. I reason that the more oil the 993 burns, the more likely that the infamous CEL problem will occur Cheers.
I think you might be referring to the Secondary Air Injection (SAI) CEL (Secondary air System, code P1411, cylinders 4-6)) & (Secondary air System, code P0410, cylinders 1-3) specifically, yes?
While all codes listed in the attachment will not throw a CEL, many of them will.
See attached file for possible Trouble Codes...
#66
You do realize that a Check Engine Light (CEL) can be for any number of reasons, yes?
#67
You got that backwards. The only grief from SAI CEL is that you have nothing wrong with the car but can't pass emissions in many states. This is one CEL you can have and keep driving without worrying that something is wrong with your car. SAI is just the most common reason for CEL.
#68
Unless I've been grossly misinformed, I know that the tube that feeds the SAI may clog and result in a CEL illumination. I'm simply saying that an illumination of the CEL due to the clogging of the SAI system is a possibly minor, but potentially expensive PITA to rectify ....even though in itself doesn't necessarily mean real internal problems with the engine or any accompanying performance penalty. Anyway I'm always interested in broadening my knowledge base on my car, please feel free to enlighten me. Cheers
#69
#70
