Is there a trick for reading the oil level on the dipstick?
#47
Can somebody please enlighten me on this checking oil BS?
So I have been afraid to overfill the car with oil, but now starting to doubt if I've been checking it right. Warm engine, idling, flat surface etc. When I pull out the dipstick, there is plenty of oil on it and you can see it extremely well. Wipe it off, put the dipstick back in, take it out and you can see some traces of the oil to the middle or so. Do it again a few times and dipstick seems pretty dry to me. I thought that was fine. Another 993er looked at it and convinced me that it was fine. But it doesn't look like it was actually dipped in oil, i.e. looks nothing like when you take it out the first time.
Finally , somebody else who thinks this ! Agree 100 % with the parts bold and underline !
#48
If you see just the oil traces you might be low on oil. The oil traces come from oil splashing when it comes back to the tank. I ran the car with open sender unit opening to see what's going on in that tank.
#49
The oil should be pronounced like the first time you pull the dipstick out, only to mid or lower end of the twisted part. There will be some traces of oil on higher part if the stick.
( As you initially reported the same as me ... the stick looking dry after putting it back in , then out , for a reading -- "Do it again a few times and dipstick seems pretty dry to me." and "But it doesn't look like it was actually dipped in oil, i.e. looks nothing like when you take it out the first time.") .
#50
Thx , so you were low on oil previously ?
#51
#53
Many years ago, I checked my dipstick and correlated it to my gauge. Since then, I have never used my dipstick again.
However, I just got a new Toyota Tacoma, and checking it's oil is terrible. The problem is that the dipstick is covered in oil inches above the "check marks"...it is residual oil in the dipstick tube. If you let that oil drain down...then you don't have that issue. Here's what I do on the Toyota...engine hot and turned off, remove the dipstick for 10 minutes to allow oil in dipstick tube to drain down...then insert stick (1) time and get reading.
With the 993, you must have the car running to check the oil, so not sure how that will work.
#54
Once you see what you supposed to see on the stick, it's really not that hard to see.
Even if you dip the stick in fresh oil you can see it on the stick.
I must say tho, on my Benz the dipstick is much better. It has plastic ending that a) wipes the tube down and b) has bunch of ridges so oil "sticks" to it. But I've checked oil on benz twice in 6 years.
#55
all this fuss over the oil.
My opinion, if you must use the dipstick, if you see any oil at all, you're fine. When you no longer do, add between 1/4 and 1/2 a quart.
Even like 3 quarts short, oil pressure is solid.
#56
Even though I know what you mean (illustration of a point) I wouldn't make a general practice of leaving your lube system down three quarts. There is no question that it wouldn't have any effect on oil pressure but even though these engines are called "air" cooled, much of the cooling is provided by the volume of oil coursing through the lube system...more oil=more cooling. Cheers
#57
Sounds like the dip stick method with napkins will be a good start. Will I be able to get 6.5 to 7 qts in with a cold engine, right now temps are in the 20s and 30s here?
#58
With cold weather you can fit more oil. Oil expands with higher temps. So I would keep qrt too low until outside temps go back up.
#59
#60
