993 Forum 1995-1998
Help to identify Performance Chip
Old Feb 4, 2013 | 06:42 PM
Spokes's Avatar
Spokes
Default Help to identify Performance Chip
Hi,
2 owners prior to me purchasing my 993 1996 they installed a performance chip. 1 owner ago, removed it as he said the car never really idled smoothly and he had the standard chip re-installed. Above is all documented in the car's service history.
I am trying to identify what / whose performance chip this maybe.. picture attached, long shot, but if anyone has seen this chip before appreciate information...
File Type: jpg
Old Feb 4, 2013 | 09:04 PM
nile13's Avatar
nile13
It's a Cypress Semiconductors EPROM. That means absolutely zero, zilch, nada. It's a generic EPROM and every chip programming house could use the same EPROM. You can not tell who did what programming on that cheap unless someone like Steve Weiner can read it for you and perhaps tell you whose it is.
Old Feb 4, 2013 | 09:21 PM
Spokes's Avatar
Spokes
Default EPROM
Yes, I agree with you. The EPROM is just the tool. I might be best doing some research and going through the previous owners in an attempt to get information. I am a little reluctant to just install it and test it.
Old Feb 4, 2013 | 11:14 PM
Steve Weiner-Rennsport Systems's Avatar
RL Technical Advisor
Indeed, a generic 27c512 chip.
One problem I see is a lack of a label over the window. This allows UV over time to erase the information flashed onto the chip. The other aspect is that all chip makers put their moniker and file numbers on that label so it can be ID'ed at a later date.
While that little window should be covered right after being programmed, the big concern is who made it and what programming values it has.
I would contact the PO to see where it came from since reputable chip makers label everything they do. The very LAST thing I'd do is install it without all the details about that.
Old Feb 5, 2013 | 12:53 AM
nile13's Avatar
nile13
Steve, I'm curious if a generic EPROM reader would pick up some sort of a header with a company name? Given that the code is still there and not erased by the light as you've pointed out.
Old Feb 5, 2013 | 01:52 AM
Spokes's Avatar
Spokes
There was a piece of masking tape over the window, I peeled it off today looking for clues.
Old Feb 5, 2013 | 11:02 AM
That depends on whether the person who wrote the software elected to put a copyright in there or not. Most professional chip makers do that to help protect their IP.
If its all in hex-decimal, its much more time consuming to read everything.
Old Feb 5, 2013 | 11:35 AM
That's one sign of a home-made chip.
Old Feb 5, 2013 | 12:31 PM
Lorenfb's Avatar
Lorenfb
"Most professional chip makers do that to help protect their IP."
IP (intellectual property) of "professional chip makers", that's a joke!
If anyone has rights to IP of a chip it's Porsche who designed the
operational code. The 'chip makers' just basically change the numbers
in a spreadsheet or some colors in a picture.
"There was a piece of masking tape over the window, I peeled it off today looking for clues."
"That's one sign of a home-made chip."
Maybe not!
And who knows whether there was an actual label, e.g. a Porsche label 126XXXXX,
there originally.
Old Feb 5, 2013 | 09:52 PM
Spokes's Avatar
Spokes
I tracked down the previous owner. Nice guy, long chat. Yep a generic chip and programme, and it didn't perform well at all. And in his view the car ran much better on the standard factory chip.
Fin.
