Scissor Lift Access Question
Can anyone who has a scissor lift (similar to Bendpak MD-6XP) advise if you can get to the other trays (pans) under the car to remove primarily to clean the underside of the car? I know I can access the engine tray.
Bob, as I recall I had no problem removing both the engine tray and the transmission tray with the Bend Pak lift in it's stock configuration. I still had the BP when I did my engine/tranny drop but I did remove the rear crossbar on the BP before I did it. The only thing I would recommend is getting (4) hockey pucks to put on the lift pads to give it a little extra lift over the frame bits. I would actually suggest getting 6 or 8 pucks and screwing/glueing 2 of them together to allow underbody parts to clear the arms.
I currently have the Max-Jax, both lifts have their plus' and minus'.
HTH
HTH
Bob, should you get one, here is a very nicely done mod to a Bendpak (and any lift like it) that discusses the rear cross bar.
Modifying Bendpak MD-6XP for a Porsche
HTH
HTH
I redid a complete exhaust system on a 928 on the lift. As noted, the only real interference would be the rear crossbar on a motor/trans drop. But, I did such with my 911 without the mod-it only took a little eyeballing to position the car correctly.
Good luck!
Bob, I had Sapphire on the lift to change trans fluid, so I took a few pics to show you what it looks like underneath. As you can see, I use the lower pads, but I snapped a pic of the others too. If you go a bit higher, there's a lock position that allows you plenty of access "inside" the lift.
http://forums.pelicanparts.com/porsc...rs-club-2.html
The first pic show the lift all the way down with the arms in. I am planning on making the recess deep enough to allow for a cover on top of the lift when not in use, just put a 1/4 recess around the edge. The third pic has a nice ideal...slope the end of the recess so it is easier to remove the lift.
[QUOTE=Bill Verburg;10195653]On a 993 I like to use lock in pucks, the 4 silver pucks in the middle. They lock into the stock lifting pads and make the whole process much more secure/
/QUOTE]
Bill can you advise where you sourced the silver pucks?
/QUOTE]
[quote=il pirata;10195840]I got them off e-bay, they used to show up there all the time, haven't looked lately
