Quick Wheel Fitment Question
I have a C2 Narrow Body 993 in which I am looking for a set of BBS LM's to put on. A member offered me his set at what I thought was a fair price, just doubting the fitment. I have no interest in rolling the fenders or such and am pretty sure I know the answer but just wanted to verify. His sizes:
Front - 18x8.5" ET56
Rear - 18x11" ET56
From my understanding stock / OEM fitment is:
Front 18 x 8" ET52
Rear 18 x 10" ET65
Would they fit?
Also....Any feedback on Wheel Enhancement?
Rear - 18x11" ET56
Front 18 x 8" ET52
Rear 18 x 10" ET65
Would they fit?
Check out Tirerack's website (www.tirerack.com).
The front wheels won't be a problem. The rears, I'm not sure as there is no 11" rear wheels listed. This is the closest one:
18x8.5
18x8.5
Original Price:
Now 0% Off: $0 (each)
$325 $325 (each) Price:
$0 (each)
See price in cart Offset: 50mm
Backspacing: 6.65"
Bolt Pattern: 5-130
Rec. Tire Size:225/40-18
Weight: 19.2lbs.
Important NotesEst. Availability: In Stock
Rear Fitment
Rear Fitment No Longer Available
18x10
18x10
Original Price:
$350 $350 (each)
Price:
$0 (each)
See price in cart
Offset: 60mm
Backspacing: 7.79"
Bolt Pattern: 5-130
Rec. Tire Size:265/35-18
Weight: 21.0lbs.
18x8.5
18x8.5
Original Price:
$0 (each)
Backspacing: 6.65"
Bolt Pattern: 5-130
Weight: 19.2lbs.
Rear Fitment
18x10
18x10
Original Price:
$350 $350 (each)
Price:
$0 (each)
See price in cart
Offset: 60mm
Backspacing: 7.79"
Bolt Pattern: 5-130
Weight: 21.0lbs.
Rear - 18x11" ET56
Front 18 x 8" ET52
Rear 18 x 10" ET65
Would they fit?
Rear - 18x11" ET56
Front 18 x 8" ET52
Rear 18 x 10" ET65
Would they fit?
Thanks guys. I kind of winced posting up a question like this but just wanted to make sure.
SleepRM3, are those LM's on your car? I have a Polar Silver C2 and can't decide whether to make the jump, I like my TT wheels but always loved the look of LM's. Just not sure if they look THAT much better.
![](http://i46.photobucket.com/albums/f101/coreseller/DSC00018.jpg)
I've posted this site before it's great for playing what ifs for wheel/tire fitment
http://www.rimsntires.com/specs.jsp
Jim
Jim
Coreseller,
11 X 18 ET56 rear definitely will not fit NB. They are more for WB cars.
My LM set has odd size 8 X 18 ET52 front & 9.5 X 18 ET56 rear. They fit wheel walls perfect. I'm running 225/40 & 265/35. No rubbing problem even lowered.
I don't think BBS make them in that combo anymore. I think 9.5 ET56 is very close to 10 ET65 LM if you can find them.
See pictures....
See pictures....
Wow Saxony, is that beautiful!!! 18 x 10 ET65 is what they are currently offering and most have up for rear fitment at this time. I was just getting close to selling myself on the fact that the Turbo Twists look just as good then you post these pics......damn lol. Thanks
That is correct. Current BBS LM offer is 10 ET65 rear for NB 993.
My friend has the 8 & 10 LM using same size tires. They look identical as my 9.5 rear. I wonder when did they stop making the 9.5 ET56.
I bought my set second hand and seller had no idea since he wasn't the original owner. Was pretty lucky, got them at bargain price.
Your Turbo Twists looks great as well. That was my second choice. Right now I'm tempted to take closer look at the new Fuchs 18s !!
The 9.5 ET 56 wheel's outer edge sits 2.65mm closer to the finder lip the inner edge sits 15.35mm further from the inner wall restrictions compared to a 10ET65.
a 10 ET65 is the factory fitment and leaves very little room inboard and only slightly more outboard(how much depends a lot on ride height)
10ET56 barely fits w/ a fender tweek at RoW M030 height
Thanks Bill for precise ET info.
Coreseller...my ride is not really that low. I have H & R sports springs that dropped the ride height by about 1.3 inches. 265/35 rear has lots of clearance left. Fenders were not rolled. Absolutely no rubbing nomatter how I try. Here are some pictures of ride height....
