First Post - SAI Issue with my 993
More questions
Re this Q in their FAQ section
"Q: My check engine light is not on, what preventative maintenance can I do?
A: The system has no maintenance intervals, cleaning the lower ports is not advisable or recommended unless or until the problem occurs"
Seems like this is not entirely correct and that replacement of the check valve could be taken as preventative maint.
I was sad to hear a lot of his 100 cars were from Texas and Fl as I am in Texas. Since I don't have a problem yet I really want to avoid one if I can.
He suspects frequent start stops are to blame and perhaps the heavy ac usage that one would expect in Texas.
I am going to use ac but not a frequent starter stopper.
My understanding it is only on during cold starts is that correct? Or am I confused. Like if you drive 20 mins. Park. Then decide immediately you want to change parking spots. It doesn;t come on again right?
Remember, the most common "cause" is worn valve guides which allow more oil into the combustion chamber, more carbon, more build up, etc… The fix for worn valve guides is a top end rebuild and there is not much preventative you can do. Frequent, regular oil changes are about it.
I would not worry that much about it. Drive and enjoy the car.
There is mixed thinking on whether high RPM runs to really heat up the motor do much good. (track cars don't seem to have the issue) My mechanic thinks it could help. But since it's kind of fun, I do it anyway. So periodically "drive it like you stole it", push the redline and work the motor hard.
If the issue arises, the flush with mechanical means and solvents did work on my car. It took a couple attempts but we got there.
Work with your mechanic. Replace the check valve and do so every couple years regardless of miles. I also do mine on the "as long as we are in there" schedule.
If you have the exhaust fully removed for any other issue consider doing a flush of the SAI system at that time. You don't want the solvents getting into the exhaust and cats.
If your car has north of 100K miles and no record of replacement, the check-valve will be dust (literallly) inside.
Actually, when ordering the new valve, the correct nomenclature is, Check Valve for Crankcase Ventilation, 993 Carrera/Carrera 4 P/N: 993-113-250-03 (aka SAI Check Valve)
Pricing ranges from $72 - $90 depending on who you do business with. The $72 price was as quoted from Susset within the last week
Here is a link to the DIY...
https://rennlist.com/forums/993-foru...eck-valve.html
By doing the maintenence work in lieu of actually addressing the SAI problem, only postponed the inevitable and spent money on items that may not have needed replacing.
HTH...
Here is a question I am really curious about. Does the potential for carbon deposits within the passages occur ONLY when the SAI pump is running OR the entire time the car is running.
Really can hurt, if the engine is over 50-60K.
"One question about the link.
"4. We'd minimize that constant revving above 5K, i.e. high revving will NOT reduce the SAI problem but likely increase it.
Note: High speed driving, e.g. freeway driving, versus "stop & go" driving does NOT reduce the likelihood of SAI problems."
Re the "note" portion. I am correct to assume the stop and go portion is ok ONLY as long as it DOESNT result in higher op temps i.e engine tray off, limited ac if for prolonged times etc?"
It's my view that it's the high temps that's one of the key factors.
"If the entire time then what is the purpose of the one way check valve?"
The valve is upstream from the passages. The valve prevents exhaust gases
from reaching the SAI pump.
However, the ports are supposed to have flow only going one way, intake to exhaust.
This is not the system on a 993 but it's a useful picture.
The check valve will not prevent all carbon build up but it's failure will allow significantly more carbon to get back up into the inaccessible narrow ports in the block.
Make sense ?
Newer cars have the same internal ports but they made them much larger diameter to eliminate a clogging issue.
In other words, is there any merit to just replacing the check valve only without cleaning the carbon out of the ports?
Make sense ?
Hi, I love to read and learn all about my 993 at this forum.
Recently bought a 97 993, after 6K, SAI light came on after the required state inspection.
Being a home mechanic trying to do least work and spend even less money and still enjoy my 97 993, I post following.
1. What would be the damages to the engine if the SAI ports or the check valve are NOT addressed for a long time?
2. What if I added a 3 way fitting (properly capped) to the tubing above the check valve to be able to add some injector cleaning solution at a regular operating hours after a good cleaning of ports?
Thank you.
Maybe all you have to do is simply replace the check-valve.
Mine was rusted through and was the root cause for my SAI issue. In other words, flushing the system was not necessary.
Do the research first > drilling would b last solution.
More tedious than difficult
Check codes first then work through them
TJ993
