Power Steering Fluid Drain & Flush
#31
Originally, I intended to remove these to drain the power steering system. Poor accessibility and the fact that some power steering fluid will still remain in the steering rack changed that plan.
#35
Greetings everyone!
In researching which power steering fluid to use on my '96, I stumbled upon a few threads on the subject, this one the most recent. It appears that many are defaulting to Pentosin CHF 202. In reading the owner's manual, it clearly states that Petosin is for turbos while Dexron II D is for naturally aspirated. So... is there a reason to use one over the other? Price difference is roughly $15/qt/lt. Thoughts?
On a similar note... Thanks for the great write-up. It will definitely come in handy in the near future.
#36
Thanks for the tips
Having searched RL and Google, none was found other than the turkey baster method (aka dilution method) of changing the power steering fluid.
IXRL8:
I was pleased to stumble across your article because I needed to change the contaminated power steering fluid in my '04 Cayenne. I had turkey basted and refilled the unmarked reservoir with ATF a couple of times, but I really wanted to get the brake fluid out of there.
The trick I learned from your article was to loosen the tube on the steering rack which I could access to allow the fluid to drain. One commenter suggested using positive pressure from a brake bleeding pump to move things along.
I kept the hoist busy for an hour, but after 1 litre of new fluid it was dripping blue, instead of red. I worked some bubbles out by turning the steering wheel with the engine off, and then burped it with a couple of tentative engine-on left-right-centre cycles. I added another .25 litres to top up the reservoir. It feels and sounds good now.
Rod
IXRL8:
Rod
#37
I'm confused. You put brake fluid and ATF in your cayenne PS??
I want to use alex's method but am concerned about disturbing the 20 year old rubber o ring gaskets around the lower lines. I'm going to try to flush from the banjo bolts, and the lower lines as a backup. Was just using Alex's guide in this thread last week to read up. Great info here.
The rubber o rings can't be sourced from power steering rack guys or the dealer.
#38
Burnt Fingers Auto Mechanics
I was hooking up the right front calliper after repairing a CV joint boot. The brake line was dry. The reservoir was unlabelled and looked pretty low. The brake reservoir turned out to be under another panel. Sh*t happens.
I turkey-bastered as much out as I could and topped it up with what the fine print on the label asked for: mineral oil hydraulic fluid. I had a gallon of high quality stuff for my Kubota. Then I read ATF is a better choice, so I diluted the brake fluid even further.
When I bought 2 litres of the correct Audi/VW fluid, I realized its viscosity is much thinner than ATF, so I flushed the system as well as I could and filled it with 1.25 litres of blue fluid.
Hey, this is the fun of "naked cliff diving."
BTW: Has it occurred to anyone that Porsche doesn't list these "O" rings because they're as common as dirt, a standard item in every mechanic's plastic box of "O" rings?
#40
Its been a long time, but I remember them being square in cross section. That might also be because they ended up being pressed into that shape over time due to the cavity they sit in.
#41
You're not in Kansas any more, Dorothy.
#44
a few notes.
- alex's method seems to be the only way to get the most fluid out without mixing.
- the dilution method is a waste of time (and fluid). The pump just doesnt circulate enough fluid to have a meaningful change. This is while using a proper extraction pump. turkey baster? forget it.
- if your car is pre 1996, there is a chance the rack is running ATF fluid (like in the 964). This was later changed by bulletin to allow Pentosin. You'll know if the fluid that comes out is reddish. These fluids cannot be mixed, plan accordingly.
second full flush revealed fresh fluid at the rack and reservoir
contaminants that came out with old fluid
old and new (o-ring shown)
