F/S EBC red stuff pads 993
NIB
F?s 1 set EBC Red stuff low dust Ceramic pads for 993 and others please check your fitment
$55 +shp
Elliot
Redstuff Product Information
Read and unbiased PAS magazine article on EBC Brakes
Redstuff Product Reviews
R90 Information
As EBC's flagship street brake pad material for prestige and faster cars above 200BHP the 09 version on EBC Redstuff sets new standards in brake performance. Redstuff has always been known for its low dust ability but the latest blend has greatly reduced the phenomenon of pad "Pick up" or disc scoring and reduced dust even further.
Tested at the UK Motor Industries Research Association (MIRA) in witnessed tests early Redstuff reduced car stopping distance in tests by almost 50 feet from 100 MPH offering a staggering 30% brake improvement.
Redstuff however as a harder compound does take longer to fully bed in to achieve its highest levels of performance (can be up to 1500 miles/2500 Kms urban use) during which time the odd "Chirp" of brake noise may be heard when starting from cold in damp and cold conditions at walking pace speed. One press of the pedal to clear the rotor of any dampness and this disappears to leave EBC Redstuff a pad that inspires confidence in all cars. The motto is be patient give the pads a full chance to bed down.
Redstuff is only available for heavier and faster CARS
Brake dust has been rated by many OEM builders to be a more serious source of complaints than even brake squeal and as such EBC Brakes is proud to bring you with this new EBC Redstuff blend what is probably a world first in a pad that is almost dust free yet delivers performance braking.
Less dust also means less rotor wear and it is almost guaranteed that your rotors will last double as long as when used with the more abrasive steel fibre brake compounds used by almost all of our competition.
$55 +shp
Elliot
R90 Information
Appears these are rear turbo pads:
Porsche 993 4 3.6L Turbocharged 1995, Redstuff Ceramic Low Dust Rear Brake Pads (DP3767C) by EBC®. FMSI : D447. This set of replacement ceramic rear brake pads offers OEM quality fit and operation with the superior stopping power, longer life, reduced brake fade, and lower dust buildup that ceramic compounds offer. Pre-chamfered edges ensure more effective braking against worn brake rotors.
