993 Forum 1995-1998
Looking for Connecticut shop for top end rebuild
Old 01-08-2013, 10:59 AM
Quadcammer
Quadcammer's Avatar
Received 1,421 Likes on 821 Posts
Originally Posted by chsu74
True but Todd has not indicated where he fills his oil level. If he is overfilling it, then I am not surprised the engine is burning it.
Edit: Deadeye is on it but Quad is correct in that if your oil level is properly filled and its still going through 1 qt every 1K miles, then you will need a topend.
this is true WRT oil fill level. Todd stated though that he's going through 1 quart every 500 miles...which is substantial.
Old 01-08-2013, 11:03 AM
Toddster
Toddster's Avatar
I was aware of the burn off factor when over filled, i try to keep the oil level half way on the dipstick when full
Old 01-08-2013, 11:08 AM
Toddster
Toddster's Avatar
Originally Posted by Quadcammer
I actually disagree. Oil burnoff is a bad thing, especially at 500mi/qt. For example, the oil in the combustion chamber firstly lowers the octane of the fuel mixture, which increases the likelihood for detonation. It further will carbon up the combustion chamber, valves, etc resulting in either increased
likelihood of detonation and reduced power. When it gets
really bad, it will start fouling plugs. All that oil in the exhaust
will certainly not do the cats any favors either.
Oil consumptions of that level are almost always indicative of valve guide problems in these cars.
While I think a compression and leakdown test are necessary
here, unfortunately for todd, I think he will need some work in
the fairly near future. The car is
obviously still driveable as is, but at some point, if you want a car
that runs well, you need to address the issue
good luck todd.
also, fwiw, I had a PPI done at
Musante and was fairly pleased with their work...despite not
proceeding with the
car.
Quad
I was considering holding off until the clutch needs work to spare my self the 8 or 10k immedualtly
Do you think i will cause any permanent damage besides the cats if i keep drivin it?
Old 01-08-2013, 11:19 AM
pkrasusky
pkrasusky's Avatar
0% leakdown across all cylinders on a 95K engine? I would be suspicious that it was not done or done incorrectly. My leakdown with 6K miles after a topend had between 2-4% on the cylinders.
was my exact sentiment for an aircooled car when I bought it, wasn't my PPI just results I was provided @ 90k
however
my usage (muchoWOT/extendedtripdigis) / consumption (1/2qt if that) @ 5k later???
scwhing!
hard to argue with that 8-)
rlme36
rlme36's Avatar
Being from around the same area I use Dan and he has been a straight shooting kind guy with me for the car. He recommended for my car to keep the oil almost to the start of the twist on the dipstick, for what it's worth
Old 01-08-2013, 11:37 AM
chsu74
chsu74's Avatar
Todd,
Did you get a PPI? What were the results on leakdown?
Old 01-08-2013, 12:06 PM
il pirata
il pirata's Avatar
Why not have a QUALIFIED mechanic visually inspect the exhaust value guides? You can also check the SAI in two ways. One is an actual volume test using a syncrometer. The other can be done with a Hammer or Porsche System II tester. Secondary air injection short test observing the oxygen sensor voltages.
All of this can be done easily and quickly.
The problem is finding a mechanic that has enough experience to know interpret the visual condition of the value guides and has the test tools.
Old 01-08-2013, 12:10 PM
K964
K964's Avatar
Call Dan Jacobs at 203-262-0569.
Old 01-08-2013, 12:33 PM
Toddster
Toddster's Avatar
sensor voltages.
tools.
I did not realize the exhaust valve guides could be tested without pulling the engine, good suggestion, thanks
Old 01-08-2013, 12:35 PM
Toddster
Toddster's Avatar
Todd,
I did do a PPI but not a leak down test, will guide wear show up on a leakdown?
Old 01-08-2013, 12:54 PM
chsu74
chsu74's Avatar
yes. Big leakdown % numbers can indicate guide wear but it is only an indication. Shops can actually wiggle the valves to "feel" for wear.
Old 01-08-2013, 12:55 PM
Quadcammer
Quadcammer's Avatar
Quad
Hard to say. Most likely not, especially if you don't drive it much. That said, its not doing the engine any favors and you will be down power.
eye balling the valves is not really gonna do it. You'd need to measure the wiggle on the valve guides, and I believe that requires removing at least the rockers, at most the valve springs (can't recall).
I think a leakdown is the proper first step here.
yes it will, but only as an indicator. You can have valve guide issues and decent leak down, but typically not vice versa.
Old 01-08-2013, 02:12 PM
Chris M.
Chris M.'s Avatar
Sorry to hear you may need some major work with so little mileage.
Here's my Dan Jacobs story from the 2011 Watkins Glen Club Race.
I am paddocked near the DJ rig. I was trying some larger tires on the rear of my SC and thought I had the clearance issues solved. When I came in from the first session I could see that I still had rubbing. A friend and I go about "altering" the fenders with a hammer. A few minutes later Dan comes walking up (never met the guy in my life) with a fender rolling tool and says, "here, try this."
Later in the weekend he gives me explicit instructions on how to stop a pesky oil leak so I can get through the weekend without a major project. He could have just as easily offered to fix it for me for what is always (at the track) a hefty fee.
Anyway, he is a standup guy that I would be using if I lived in the area.
Old 01-08-2013, 03:28 PM
chsu74
chsu74's Avatar
I have used Dan for alignments on my 996 and 993TT. I will not go anywhere else. One of my toe links was worn out on the TT when doing an alignment and he had a spare in stock to clean my car up. I would use him more if he was not 1 1/2 hr away from me.
Old 01-08-2013, 03:35 PM
Toddster
Toddster's Avatar
Thanks everyone,
I have scheduled an apointment with dans shop for the 29 th
I will keep u all posted, wish me luck
P.S.Fister Stage IIIs just arrived via UPS
CANT WAIT TO POP THOSE BABIES ON
Quick Reply: Looking for Connecticut shop for top end rebuild
